help! B16a Obdo 16 code trouble
Code 16 is a rather nebulous code. Usually means an issue to do with injectors. Could be poor contact from the ECU to the injector, the injector itself. It can also be caused by a bad solder joint in the main relay..
well i tried changing main relays and im still throwing a cel code 16. I have 89 si w/ obd1 conversion harness and 650cc precision injectors wired to resistor box. Is there a way to test the resistor box? how about the injectors, can i test them to see if they are working properly? Has anyone fixed this problem before on HT? I need help.
I found this link on how to test the injectors.
http://www.crxcommunity.com/viewtopic.php?f=4&t=45572
