need help with no turn over.
Old Mar 8, 2011 | 07:07 PM
turbohatchBnuts's Avatar
Default need help with no turn over.
just did a 89 civic si car harness swap from a 88 std civic. Fuel pump primes but starter doesnt turn over. Starter worked before i did the swap. Any ideas on what it could be? I checked all the grounds.
heres a link to what i have done so far.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/my-88-std-civic-build-2705529/
Old Mar 9, 2011 | 03:26 AM
Default Re: need help with no turn over.
Any ideas?
Old Mar 9, 2011 | 05:25 AM
thatsJDMyo88's Avatar
when u say harness swap do u mean tail lights to headlights or just converted it dpfi to mpfi
Old Mar 9, 2011 | 05:53 AM
DOHC_Hatcher's Avatar
check for voltage at the signal wire
Old Mar 9, 2011 | 06:13 AM
Ok I will check for voltage also does a 89 civic Si have a safety netural switch? My 88 std seems to not have one.
Old Mar 9, 2011 | 05:00 PM
i figured it out it was the netural safety switch. it was unpluged and i had to get one. It cranks right up but now im throwing a cel code 16 fuel injectors is there any way to test and see if they are working properly.
Old Mar 14, 2011 | 10:11 AM
noid light or use a screwdriver to listen for the solinoid to click
Old Mar 14, 2011 | 11:02 AM
Yea I figured it out I didn't have my netural safety switch plugged up. 1988 Civic std. Don't come with one and I used all 1989 civic Si harness witch do have one. Now im throwing a cel code 16 im trying to figure it out. Any ideas???
Turbolsvtech
15
Nov 23, 2011 06:51 AM
turbohatchBnuts
11
Mar 9, 2011 05:53 PM
rbwdriven
Oct 24, 2008 02:54 AM
4cefedcrx
Apr 16, 2006 07:18 AM
oldskool4life
13
May 15, 2005 01:58 PM
