95 accord bad noise.
Old Mar 8, 2011 | 03:02 PM
campfire's Avatar
Icon2 95 accord bad noise.
I just got a 94 accord lx. It's a 4cyl 2.2. From a friend told me it sat around for almost two years. I fix a few things on it and did all the fluids. It starts fine but sometimes when I start it it has a realy loud noise, if I turn it Off then restart it, it's not there then runs fine with no noises. the noise I hear is like a grinding noise not from timing belts. Is from the passenger side. What can this be?
Old Mar 8, 2011 | 05:12 PM
holmesnmanny's Avatar
Default Re: 95 accord bad noise.
Originally Posted by campfire
I just got a 95 accord lx. It's a 4cyl 2.2. From a friend told me it sat around for almost two years. I fix a few things on it and did all the fluids. It starts fine but sometimes when I start it it has a realy loud noise, if I turn it Off then restart it, it's not there then runs fine with no noises. the noise I hear is like a grinding noise not from timing belts. Is from the passenger side. What can this be?
Try to either narrow down the location or make a video of it.
Old Mar 8, 2011 | 05:14 PM
poorman212's Avatar
Does it sound like the starter? It could be the bendix of the starter drive is hanging up. Might pull the starter and check the movement of the bendix.
EDIT: Sorry holmes....slow typing
Old Mar 8, 2011 | 05:35 PM
campfire's Avatar
But poorman it fire's right up like New car does
P.s working on a Vid for it should have tomorrow.
Old Mar 8, 2011 | 05:43 PM
poorman212's Avatar
Yes but if the bendix hangs in the flywheel every now and then....it starts, yes-but the engine is then trying to turn the starter bendix. Sorry wasn't clear-not saying it wasn't pushing out, was suggesting it may not be retracting all the way.
Anyway-yes a vid with sound would help.
Old Mar 8, 2011 | 07:02 PM
Is there anything wrong with the ignition/key cylinder. Perhaps it's sticking open and the starter is stuck cranking.
Old Mar 8, 2011 | 10:36 PM
campfire's Avatar
Na just put a new ignition in few nites ago. I going to get a new starter and new timing belt tomorrow then make the Vid if it still has the sound. Thx for the input
P.s. I have to save my last post for Vid Im a new member so I have to wait 15 days for more post sry
HondaDadi
Mar 30, 2016 03:12 AM
mfiazzo
Oct 8, 2013 05:13 AM
RAS86
May 28, 2013 07:46 PM
ddolezal
Mar 30, 2008 11:03 AM
