93 honda civic turning off when stepping on gas
Old Mar 8, 2011 | 02:25 PM
Eddog85's Avatar
Default 93 honda civic turning off when stepping on gas
I was wondering if anyone can help me. my civic just recently started turning off when i come to a stop and step on the gas. It also as trouble starting somtimes. But the weird thing is that it runs good somtimes and suddenly it will start with the problems. I checked my fuel pressure and it was 35 psi and with the vacum hose out it was 45 psi so i believe my pump is good and the pressure was holding when car was turned off. Would anyone have an idea what can it be.
Old Mar 8, 2011 | 03:00 PM
fallrivercolin's Avatar
Default Re: 93 honda civic truning of when steping on gas
Check your plug wires, they could be arcing out when the motor torques.
Old Mar 8, 2011 | 05:44 PM
Former User's Avatar
Default Re: 93 honda civic turning off when stepping on gas
...also cap, rotor and ignition timing.
Any CEL codes?
Old Mar 8, 2011 | 10:22 PM
Eddog85's Avatar
well my spark plug wire are ok tested those, distrubitor was just replced and timing is on point. I think it might be my IACV there is a buzzing sound coming out of it, what you guys think would this cause the car to turn off and trouble strating..
Old Mar 9, 2011 | 06:18 AM
What happens if you unplug the IACV? Does the buzzing go away? Does the engine start? I wouldn't think so, but it's worth a try.
SKDRCR
Aug 24, 2013 01:37 PM
thaisayz
20
Dec 28, 2007 03:16 PM
gdrum
Oct 11, 2006 09:28 AM
BolivianDc2
Aug 22, 2006 03:30 PM
ToiletFetusSushi
Sep 30, 2004 09:12 AM
