Tranny Leak?
As some of u know i put a new clutch in my car and it runs good. When i got back from work I looked under my car and i saw tranny fluid on the ground. It looks like its leaking from the bottom of the tranny. Was there anything i was suppose to do before i put the tranny back together? The leak isnt too bad but i would like to fix it. Could it be because i used regular oil rather than Honda tranny oil? Any info would be appreciated and thanx for the help.
I didnt use any Hondabond. Was i suppose to? Now im talking about where the tranny meets the block.
Could it be residual oil that came out when you pulled the axle out of the transmission or is it a leak?
cv shaft impit seal... check where the joints go into the tranny.
the type of fluid will have nothing to do with the leak.
sack-whosiziz leaking
Weird, I know people how have had theirs break after the first time droping the tranny. I've droped mine a total of 6 times so far and have not had it leak 1 drop
petty$rep
18
Oct 12, 2006 07:53 AM
on me
