Engine overheating after motor replacement
I just replaced the stock d15b7 for a jdm d15b and it runs just fine but it starts overheating right away, and the cooling fan does not come on. the temperature readout is not accurate and the car does not idle high when its cold it idles at 800 then 600. coolant levels are fine, a little black smoke came out but that might be left over from the old oil burning engine. Both coolant lines become hot so thermostat is functioning on a basic level. The car also has NO POWER. i punch it and it takes forever to accelerate. no white smoke coming from the engine and the black smoke has cleared up. the new motor has up to 45k on it. Any thoughts?
If the fan does not come on, have you tested the thermo switch to see if it is working? For the water pump, pop the radiator cap (when cool) and give it some gas (will need a friend to help), after the thermo opens up, you should see water being pulled down into the radiator. If the bottom hose is as hot as the top you need a new thermostat, same goes if the top is hot and the bottom is cold.
it appears the water pump is doing its job. not sure on the thermo switch...but like i mentioned both coolant hoses get really hot after a few minutes
Its probably not your cooling system, though I would probably replace the thermostat, if it has been a while. I would also look into why the fan is not kicking on. I would look into timing retardation as your main issue. How many degrees before or after TDC are you currently running it at?
jetlude
Feb 1, 2007 05:24 AM
shoebox
12
Mar 22, 2005 01:07 PM
ferio
Mar 24, 2002 02:33 PM
