Engine suddenly lost power and died, rpm guage jumped about
Old Mar 7, 2011 | 10:31 PM
kamikazi_racing's Avatar
Default Engine suddenly lost power and died, rpm guage jumped about
Alright, well for the past couple months my car has been bogging about. Like, sputtering in low rpms. I've changed the spark plugs, wires, cap, rotor, coil, fuel filter, rail, injectors, pressure regulator, o2 sensor, even put on the stock exhaust and airbox (unrelated to the issue), and recently, I warrantied out my ngk wires and it started to run perfect; like nothing was ever wrong.
Now, my problem is that when i was driving home today, it just... died.. it suddenly lost power and my rpm guage just jumped about. and when it DOES start, it quickly dies. now im wondering, is it the distributor after all? any insight...?
Old Mar 7, 2011 | 11:09 PM
phoxking's Avatar
Default Re: Dead car?
possibly be your dizzy went bad..someone correct me if i'm wrong, but if the dizzy isn't working properly, your car shouldn't be able to run either..btw* kind of late, but their was no need to change the o2, that's just for emissions basically.
Old Mar 8, 2011 | 04:12 AM
94EG8's Avatar
Seagull Management
Year? Model? Trim level? All would really help here, any CEL codes?
Old Mar 8, 2011 | 06:26 AM
Former User's Avatar
Have the igniter unit tested at an auto parts store.
Old Mar 8, 2011 | 11:48 AM
Default Re: Engine suddenly lost power and died, rpm guage jumped about
Alright, so i baught a new distributor, and it will start now, but does the same thing, the rpm meter jumps about and then dies. but it will stay on longer. i put my foot on the gas about halfway. A friend told me it could be water in my fuel? does anyone think this is correct?
95 honda del sol, d16z6
Old Mar 8, 2011 | 11:55 AM
well, just tested the spark and it has spark to all cylinders. and it stays on now. but the rpm meter jumps still and idles like ****............
Old Mar 8, 2011 | 11:58 AM
Any CEL codes?
Did the new distributor include a new cap and rotor? What are the condition of the plugs and wires?
**barely stays on.
Old Mar 8, 2011 | 12:00 PM
well, its obd1, and im finding it hard as **** to find someone who can test it's codes. it died on the side of the road last night, and i had it towed to my house. i JUST baught plugs cap and rotor a month ago, and i had new ngk wires ready to put in it last night. now all that is in, and the rpm meter still jumps around. and it idles rough..
Old Mar 8, 2011 | 12:12 PM
Jimster480's Avatar
its the ICM. You can test teh codes by jumping the 2 pin service connector under the passenger side dash near the ECU. I had the same issue when my ICM died. Either the connections on the ICM came lose or the ICM itself is bad/going bad.
Old Mar 8, 2011 | 12:22 PM
You can do this yourself. Click the CEL link in my signature.
The jumping tach may be the sign of a bad igniter unit or loose wire..
Old Mar 8, 2011 | 12:34 PM
I thought the ICM was built into the distributor. and i JUST changed the distributor... URGGG...
Old Mar 8, 2011 | 12:35 PM
Alright, thanks for the link.. and yeah, turns out there is no bulb where the CEL bulb should go -____-.. on my way to find a paper clip though
admess188
Aug 13, 2011 07:29 PM
blackeg
Feb 22, 2011 12:16 PM
axionm1k
Apr 2, 2008 06:58 AM
95vtecsrus
33
Aug 12, 2006 12:10 AM
94gsr
Apr 20, 2004 10:01 AM
