CAI & Hydro Lock?
Old Sep 26, 2002 | 11:14 AM
all420's Avatar
Default CAI & Hydro Lock?
Hey. I did a search and seriously found nothing on this topic. Maybe I did it wrong?
Anyway. I am just wondering about the threat of having water sucked in through your CAI? Everyone around me that I tell that I'm getting a CAI, they all just laugh and tell me my engine is going to explode. I have seen the AEM Air-Bypass. How well does that work? What have you all done to avoid this disastrious problem?
Thanks Alot.
Old Sep 26, 2002 | 11:23 AM
greensleeper's Avatar
Default Re: CAI & Hydro Lock? (all420)
I have had an AEM CAI for over a year with no bypass valve. Yes it gets wet and makes fucked sounds no and then - but I consider that cleaning it
Seriously though. I've never had a problem. Just don't try and ford any rivers.
Old Sep 26, 2002 | 11:31 AM
Conechaser's Avatar
Default Re: CAI & Hydro Lock? (greensleeper)
<--Has hydrolocked his motor twice.
Old Sep 26, 2002 | 11:32 AM
Default Re: CAI & Hydro Lock? (94Accord)
by your own fault correct?
it's not you're driving along and bam... d'oh hydrolocked?
Old Sep 26, 2002 | 11:33 AM
Brandon's Avatar
Life is Suffering
If you get a CAI, just get a bypass valve. They work, and it is cheap insurance.
Old Sep 26, 2002 | 11:35 AM
Conechaser's Avatar
Default Re: CAI & Hydro Lock? ( Brandon)
Heavy down pour rain, road flooded out, nowhere to go, etc.
I don't recommend the bypass valve, its prone to break pieces end up in your throttle body causing your throttle to get stuck open.
Old Sep 26, 2002 | 11:36 AM
despite my good luck this is good advice
This was recalled and they have fixed it.
Old Sep 26, 2002 | 11:48 AM
ArchAngel Sabastian's Avatar
New User
i run a CAI all the time cept winter and early spring, it snows here and **** gets deep water in some spots and in the winter snow of **** i dont need any extra hp from the CAI so i just toss the stock box back on.
Old Sep 26, 2002 | 11:50 AM
GimpyAccord's Avatar
Default Re: CAI & Hydro Lock? (ArchAngel Sabastian)
I ran an AEM CAI for 3 years, and this generic one now for 2... no bypass and 4 of those years was in my home state of Florida.
just dont be silly and it wont happen to you.
Old Sep 26, 2002 | 11:53 AM
New User
Default Re: CAI & Hydro Lock? (GimpyAccord)
also dont drive threw lake's, ponds.
Old Sep 26, 2002 | 11:57 AM
Gennady's Avatar
New User
You've got to be ******* kidding me.
https://honda-tech.com/zerothread?id=209991
https://honda-tech.com/zerothread?id=242885
https://honda-tech.com/zerothread?id=228446
https://honda-tech.com/zerothread?id=239622
https://honda-tech.com/zerothread?id=238561
https://honda-tech.com/zerothread?id=228929
https://honda-tech.com/zerothread?id=176282
https://honda-tech.com/zerothread?id=270440
https://honda-tech.com/zerothread?id=202453
https://honda-tech.com/zerothread?id=216638
This search took me 2 minutes.
Old Sep 26, 2002 | 11:58 AM
Default Re: CAI & Hydro Lock? (Wont be beat)
2 minutes !?!??!?!
that's totally unacceptable! a search should require not effort nor time what-so-ever!
refuckingdiculous.
Old Sep 26, 2002 | 12:02 PM
Nick M's Avatar
Ive had a CAI since '00, no problems yet. I leave it on through winters here in NY.
As far as the "fixed" bypass valve goes, we got a 93 prelude S in at that dealership that was hydrolocked that had the "fixed" bypass valve. It broke and sucked up water.
Just be smart in the rain and hope you dont get stuck like Steve did. If you are that concerned about hydrolocking make your CAI in two pieces for an easy conversion to a short ram if need be.
Old Sep 26, 2002 | 12:13 PM
all420's Avatar
Default Re: CAI & Hydro Lock? (Nick M)
Thanks for all of them help.
Sorry about the search thing man. I typed in Hydro Lock and nothing came up for me. Seriously.
And to the guy who has hydro'd his engine twice. Doesn't doing that totally destroy your engine, or are people around me handing me a whole line of bullshit?
Thanks again.
Old Sep 26, 2002 | 12:15 PM
Yeah your engine gets fucked in the goat ***.
At which point its cheaper to replace than rebuild.
Old Sep 26, 2002 | 12:33 PM
would someone please hydrolock your H23A1 and sell me the rotating assembly cheap?? assuming you didnt bend a rod?
Old Sep 26, 2002 | 12:43 PM
Martaigne's Avatar
I hydrolocked my motor once, threw #1 rod through both ends of the block.
Thus the 'bomb' from Soy Bomb. Boom.
Old Sep 26, 2002 | 12:48 PM
New User
Default Re: CAI & Hydro Lock? (Martaigne)
I hydrolocked my motor once, threw #1 rod through both ends of the block. Thus the 'bomb' from Soy Bomb. Boom.
i remember that..
Old Sep 26, 2002 | 01:13 PM
3700 Vtec's Avatar
I've had an AEM CAI for 2 years now and I have never had any problems. I bought a bypass valve, though never installed it because it causes a slight loss in power, even though AEM improved the design by adding a plastic ring so that the foam dosn't get sucked into the throtle body, I figured that I'll be fine without it.
Just be aware of what the road is like that your driving on when there is a great deal of rain.
Old Sep 26, 2002 | 01:18 PM
Martaigne's Avatar
Default Re: CAI & Hydro Lock? (3700 Vtec)
though never installed it because it causes a slight loss in power.
BS. If anything you'd lose like 1hp or so, nothing worth losing an engine over.
Old Sep 26, 2002 | 01:20 PM
3700 Vtec's Avatar
We never get a lot of rain or snow in Columbus.
Old Sep 26, 2002 | 02:02 PM
Martaigne's Avatar
Be glad, it's been raining for nearly two weeks straight here.
Old Sep 26, 2002 | 02:06 PM
Nick M's Avatar
Did you miss this?
Old Sep 26, 2002 | 02:39 PM
Martaigne's Avatar
Generally not a problem though, unless you are either missing your fender lining like me, or you drive through 12" of water with the throttle mashed.
Old Sep 26, 2002 | 02:40 PM
Accord94DX's Avatar
rolled aem CAI for 3 years now. never hydrolocked.
Dont drive into large bodies of water.
