brake porportion valve
Old Sep 26, 2002 | 10:51 AM
VSM EXtasy's Avatar
Default brake porportion valve
is the master cylinder and porportion valves the same in the 99-00 Si and the 96-00 EX???
Spade's Avatar
Default Re: brake porportion valve (VSM EXtasy)
Nope.
Old Sep 26, 2002 | 12:34 PM
maxim's Avatar
Default Re: brake porportion valve (Spade)
Neither one are the same, but if you are doing a rear brake conversion on your 96-00 civic you will only need the proportioning valve from a 99-00 Si, forget about the master cylinder because there is not a lot of difference in the capacity of a 96-00 Civic EX and an Si prop valve. My suggestion is, only change out the master cylander(to a 94-01 integra MC) if you are getting larger front rotors and calipers.
rockin_remz
Dec 1, 2005 01:05 PM
