97 civic ex - lights surge and the speedometer goes crazy
Old Mar 7, 2011 | 04:41 PM
enigma2446's Avatar
Default 97 civic ex - lights surge and the speedometer goes crazy
Ok so my alternator went out on my way home and I was able to charge the bat up a bit to get it home....I replaced the alternator and now the lights surge a little bit and the speedometer goes crazy when I step on the gas......please help!!!!!!!
Old Mar 7, 2011 | 04:44 PM
Former User's Avatar
Default Re: 1997 honda civic ex problems
Is 7.5A dash fuse 15 blown?
Old Mar 8, 2011 | 06:12 AM
enigma2446's Avatar
havnt checked ot yet but i will...is that tge alternator fuse?
Old Mar 8, 2011 | 06:22 AM
Yes - voltage regulator. Any CEL codes? If so, click the Fuse 15 TSB in my signature.
Old Mar 8, 2011 | 07:55 AM
enigma2446's Avatar
Default Re: 97 civic ex - lights surge and the speedometer goes crazy
yep that did the trick no more surges and the speedometer works...but i still have a check engine light on?
Old Mar 8, 2011 | 08:40 AM
Reset the ECU to clear the codes. If the problem returns, read the TSB.
Old Mar 8, 2011 | 09:44 AM
enigma2446's Avatar
how do i reset it without a reader
Old Mar 8, 2011 | 09:46 AM
Remove the 7.5A hood Back Up fuse for 3 or more minutes.
Old Mar 8, 2011 | 09:48 AM
enigma2446's Avatar
do i remove it when its running or when its off..and the back light fuse is located under the hood right
enigma2446's Avatar
back up light fuse***
Old Mar 8, 2011 | 09:51 AM
Engine off
Under hood - see label on lid of hood fuse box
Old Mar 8, 2011 | 11:11 AM
ysosrs's Avatar
or u could just disconnect your battery for 10 seconds
Old Mar 8, 2011 | 01:12 PM
enigma2446's Avatar
ok so i did all that and everythimg seemed fine but i let it run for about 3 min and the fuse for the alternator keeps poping...i dont know whats cousing it...i checked all the fuses and found the cooling fan fuse under the hood 20amp was poped as well..so i replaced it and the alternator fuse and started up it ran beautful for another 3 min then the alt fuse blew again?????????????????but the cooling fan was still good so i shut it off and banged my head on the wall please help
Old Mar 8, 2011 | 04:42 PM
enigma2446's Avatar
please please please help me!!!!
Old Mar 8, 2011 | 05:11 PM
Hello! Did you happen to read posts #4 and #6?
Old Mar 8, 2011 | 05:22 PM
jdmeg6118's Avatar
Nice info i had the same problem
Old Mar 9, 2011 | 05:45 AM
enigma2446's Avatar
ok what are the chances it will work...i downloaded the adobe repair guid for this problem
Old Mar 9, 2011 | 05:56 AM
grumblemarc's Avatar
The Grumpiest
Why not try the fix and find out? It will either correct the issue or not. Wondering about it won't get it repaired.
Old Mar 9, 2011 | 06:01 AM
enigma2446's Avatar
i know im doing it regardless just wanted to see how many people can give a a good awnser verses a bad one thanks
Old Mar 9, 2011 | 06:32 AM
It's an extremely common problem. That's how I guessed it in post #2 and guided you to the TSB.
Old Mar 9, 2011 | 06:44 AM
enigma2446's Avatar
ok sounds good...so i should see damged wire under there where its shorting out?
+honda_monkey+
Sep 26, 2009 12:10 AM
sweethondachix21
May 28, 2008 07:02 AM
62maxx
Oct 25, 2006 03:45 PM
Pablo Escobar
15
Jul 4, 2006 07:24 PM
Patrick_S
Jun 8, 2006 07:07 AM
