How far do you compress the spring on the exhaust?
Old Mar 7, 2011 | 03:48 PM
pityocamptes's Avatar
Default How far do you compress the spring on the exhaust?
I was curious, as I had to pull the exhaust where the down pipe and cat meet on my 1998 Honda Civic while replacing the rack and pinion. I basically tightened the bolts all the way down until the little round stopper on the bolt itself bottomed out on the flange. Is that correct? Seems to run properly... thanks!
Old Mar 7, 2011 | 07:24 PM
ddd4114's Avatar
Default Re: How far do you compress the spring on the exhaust?
Yeah, that's right. The springs are just there to keep the flanges and bolts preloaded.
Old Mar 7, 2011 | 08:04 PM
NotAJDMFanBoy's Avatar
No, the springs are there to let the pipes flex a little if need be. Thermal expansion, hitting things, etc. That's why they have that semi bowl shaped donut gasket instead of a flat gasket.
Old Mar 8, 2011 | 03:04 AM
ddd4114's Avatar
We're saying the same thing.
Old Mar 8, 2011 | 11:01 AM
So your saying NOT to bottom the "bead" looking thing that is on the bolt against the flange? Basically run the nut until it stops turning???? Because thats what I did. Do I need to back it out some now, or should I be fine? Thanks!
Old Mar 9, 2011 | 08:08 PM
The bolt gets tightened down all the way, and the spring is pressed down by the head of the bolt. The bolt is just there to hold the spring in place so it can work.
And DDD4114, sorry, yeah we were saying the same thing, I was just elaborating a little.
Old Mar 9, 2011 | 08:44 PM
Former User's Avatar
Torque = 16-ft-lb
Wdpfreak145
May 30, 2013 08:54 PM
4dr_Noob
Aug 5, 2012 07:28 PM
aust 97 coupe
Nov 10, 2008 06:45 PM
speedymon
Oct 17, 2003 02:04 AM
