94 civic ignition ?
Old Mar 7, 2011 | 10:26 AM
team 15's Avatar
Default 94 civic ignition ?
when i turn key to start, the car starts,but when the key returns to on, it die instantly.
I have to hold the key to start in order for it to stay running. if not the car die instantly.
Can this be my ignition switch or something to do with my ignition?
Old Mar 7, 2011 | 10:29 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 94 civic ignition ?
Sounds like the switch to me.
Old Mar 7, 2011 | 10:30 AM
Crashtestdummy's Avatar
It could be a bad switch but first check and see if there are any loose connections at the alternator or distributor. That would cause it to die pretty quickly, could also be a vacuum leak at the gasket between the throttle body and inake manifold.
Old Mar 7, 2011 | 10:46 AM
team 15's Avatar
i looked for loose connection under the fuse box, alternator and distributor and no loose connection. Finally i got it to start by touching the ignition switch wires(black one) and it running right now. But don't know if it will ocur again. i just wiggle the black wires and it start right up even when the key returns to on.
Old Mar 7, 2011 | 10:49 AM
pityocamptes's Avatar
Its your switch.
Old Mar 7, 2011 | 11:19 AM
Yeah that sux definitely the switch
Old Mar 7, 2011 | 12:53 PM
team 15's Avatar
that sucks
Old Mar 7, 2011 | 12:54 PM
team 15's Avatar
should i buy the whole complete ignition and lock cylinder or just the switch?
JuneBugDrfter
Nov 30, 2013 07:57 AM
Civic Racer X 7
Feb 25, 2011 12:31 PM
b00sted4dr
Jul 31, 2006 05:00 PM
Un0Turb0-WP
Oct 19, 2004 11:45 AM
