those with h23 vtecs please read...
Old Sep 26, 2002 | 10:28 AM
user 9782082308's Avatar
Default those with h23 vtecs please read...
I was thinking about doing the swap til I started doing the math. I know r/s ratio isn't everything, but I don't want an engine I have to rebuild every 50,000mi.
My questions are:
1. How long have you had this converion?
2. Any problems?
3. Did you use forged pistons and iron sleaves to cobat the wall loads?
4. What were the hp/ tq gains?
5. Where did you get the parts for the conversion?
Thanks for any insite.
Old Sep 26, 2002 | 03:07 PM
Qfactor's Avatar
Default Re: those with h23 vtecs please read... (racerx)
I had this conversion since 98' no problems at all, it's my daily driven car to and from track. bone except when I switched to crower rods and type S slugs.
dyno results where 190 hp and 161 tq at the wheels corrected I had the h22 and got my self a crank and rods from an accord at the junk yard for fifty dollars(best 50 dls I've spent for hp). currently I will be resleeving block to 90mm and port and polish head, ext hone the intake manifold along with ferrea ss valves bronze guides, Jun springs,ti-retainers along with bumpsticks. also will be running a vacuum pump,electric pump and water injection. My goal is 240 hp at the wheels.
dyno run pic. http://www.imagestation.com/album/?i...8496068&idx=35
[Modified by Qfactor, 5:00 PM 9/26/2002]
[Modified by Qfactor, 5:01 PM 9/26/2002]
Old Sep 26, 2002 | 05:37 PM
Fly1865's Avatar
Default Re: those with h23 vtecs please read... (Qfactor)
So you have an Accord crank and rods in your H22? Which Accord parts did you use and what year is your H22? And is was just has simple as switching the H22A internals with the Accord ones? What about main bearing and will that Accord crank clear the oil jets on the H22? Sorry about all the questions it just i've never heard of this being done with Accord parts.
Thanks
Old Sep 26, 2002 | 05:46 PM
ImportReview
Guest
Posts: n/a
My questions are:
1. How long have you had this converion? Almost 5 years, put about 80,000 miles on it.
2. Any problems? NONE
No, used stock Honda pistons.
I had like 181 WHP 150 TQ
Not hard.
BTW, I took it to 8,000 RPM like every day day for 4-5 years.
So that tells you, and is a good lesson...that R/S ratio is totally blown out of proportion and not as important as alot of people think.
Jeff
Old Sep 26, 2002 | 05:50 PM
Qfactor's Avatar
Default Re: those with h23 vtecs please read... (Fly1865)
I used the accord's crank and rods(same as H23). My engine yr. is a 93'. the swap is as simple as changing parts. the main and rods are the same specs as h23/h22. oil jets will have to be modified in order to clear counter weights no big deal you'll see when you do it.
Old Sep 27, 2002 | 10:30 AM
Fly1865's Avatar
Since your H22A is a 93 and mine is a 98, Do you think there would be any difference in the setup. Cause i know that the H22A and the H22A4 cranks have different part numbers which would tell me they are different.
Old Sep 27, 2002 | 01:55 PM
Yuleluder's Avatar
So what your saying is the accords(what years) crank and rods are the same as the H23 crank and rods(93 to 96)?
Old Sep 27, 2002 | 05:41 PM
Qfactor's Avatar
Default Re: those with h23 vtecs please read... (Yuleluder)
Accord 90-97 only have the same main and rod journals sizes
Accord 98-02 main journal are bigger rod journal are the same size as 90-97
you can buy the 98-02 crank new for under $300 but you will have to reground to 90-97 specs. you can also get a short block 90-97 for about 100-200 depending on your local junkyard. also 97-01 prelude crank and rod journals are the same specs as 93-96 prelude.
Old Sep 27, 2002 | 06:11 PM
se93's Avatar
Hmmm, this upgrade sounds very interesting! Damn, i had two 90-97 mint blocks (with all internals) and sold them both!
Regards,
Mark Perez
Import Performance
Old Sep 27, 2002 | 06:43 PM
WOW, good info. Thanks. The places around here will only sell me a complete h22. I imagine it's not worth getting the parts new. So , where can I get the head by its self???
Old Sep 27, 2002 | 10:22 PM
KTeller8's Avatar
lol want to buy it and keep the parts i need a short h22 block
i have a 96 lx f22b2 engine sitting here
Old Sep 27, 2002 | 11:17 PM
Fly1865's Avatar
So, i have a H22A4 motor, and if I used a H23 crank and rods or Accord crank and rods if would work without having to reground the crank? plus the rework of the oil jets.
Old Sep 29, 2002 | 07:57 AM
se93's Avatar
Anyone else running the 90-97 Accord crank/rods with the H22 block?
Regards,
Mark
Old Sep 29, 2002 | 10:12 AM
flowfx's Avatar
anyone know a good place for h22 heads only?
Old Oct 6, 2002 | 05:58 AM
se93's Avatar
Default Re: those with h23 vtecs please read... (flowfx)
ttt
Mark
Old Oct 6, 2002 | 07:45 AM
BoostedH23a1's Avatar
Default Re: those with h23 vtecs please read... (se93)
i have a 2 f22s what do i need one is VTEC f22 and the other is non VTEC f22..
Old Jul 27, 2003 | 10:33 PM
nickwilmot's Avatar
Default Re: those with h23 vtecs please read... (BoostedH23a1)
Just read the whole post and few other ones on the same subject. Well I heard of putting the H23/F22 Crankshaft and Rods into a H22 and that would make it into a H23 Vtec. But my question is, what exactly changes?? The Compression or the stroke or what ...sorry a little clueless to this.
Old Jul 27, 2003 | 11:32 PM
Default Re: those with h23 vtecs please read... (nickwilmot)
WOW! Back from the dead.
The stroke changes. From what I understand tho, the f22 crank has smaller journals so it will have to be modified. What the advatage is to using an f22 crank is I still don`t know. Talk to 2point6. I believe hes used both cranks for a stroker vtec.
Old Jul 28, 2003 | 12:32 AM
Fly1865's Avatar
I see that the F22 and H23, Accord 90-97 and Prelude S, Si 92-96, can be used in an H22 block 93-97. Cause in 97 they changed the Mains in the H22A in 98 to 55mm( don't know the size pre to that). And if you have a H22A 98+ you have to use the 98+ Accord crank cause the mains are the same size as the 98+ H22A. I think its just a cheaper way to get that extra .1 out of the motor.
Also i just found that the 90-97 Accord and Prelude S, SI 92-96 used 2 different cranks
13310-P0A-000
13310-PT3-315.
I don't know if there is a difference I would think you could use one or the other but these will only work in a 93-97 H22. In thoery.
Anyone have anyother ideas?
h22accordcoupe
Nov 8, 2012 09:38 AM
misterpsycho
Jan 11, 2008 04:20 AM
tmrtwo
Feb 13, 2007 03:14 PM
gaydm.accord
35
May 8, 2005 03:42 PM
Ms. Pretty
Feb 19, 2004 07:41 PM
