VTEC not working
Old Mar 7, 2011 | 01:50 AM
Monstarrr*'s Avatar
Default VTEC not working
Just built an lsv, with a b16 head and vtec doesn't work. Previous motor was a b16a and the vtec worked in my eg hatch VX. I used the solenoid on my b16 on the lsv. Checked the oil for dents, checked and refilled my oil, and replaced the pin and gasket in the head. I was wondering if connecting the oil pressure sensor on the BLOCK would be necessary to solve the problem. Or any other suggestions???
Old Mar 7, 2011 | 04:01 AM
NOYGDB's Avatar
Default Re: VTEC not working
First thought would be yes. Is it the sensor or the sending unit? Or are they even seperate on those>>?
Old Mar 7, 2011 | 04:25 AM
Ruckus2009's Avatar
Biggest problem with the ls vtec is trying to get the vtec to work right.
Old Mar 7, 2011 | 10:21 AM
virgineg6's Avatar
hook up a light to the VTEC solenoid, to see if its engaging
Old Mar 7, 2011 | 11:55 PM
Monstarrr*'s Avatar
The LS block came with no oil pressure sensor on the block in the back, other than that the solenoid's oil pressure switch is connected.
Monstarrr*'s Avatar
It sure is -__-
Old Mar 7, 2011 | 11:56 PM
Monstarrr*'s Avatar
How do you hook up the light?
Old Mar 8, 2011 | 12:41 AM
virgineg6's Avatar
i have no idea but it gets hooked up so when VTEC engages the light comes on, that way you know for sure if its engaging or not and just cant feel it.
Old Mar 8, 2011 | 12:56 AM
evo500's Avatar
throwing any codes?
Old Mar 9, 2011 | 01:26 AM
TypeSiR-G's Avatar
Question: If i just swapped a JDM ITR motor and ecu into my 94 GSR and im getting an engine check light (i think code 10 and 20) and my VTEC isnt working, what could be causing this problem? What things can i look for to fix this problem?? Please help. thanks!
Old Mar 11, 2011 | 08:44 PM
Monstarrr*'s Avatar
Originally Posted by evo500
throwing any codes?
o2 sensor
Old Mar 12, 2011 | 01:32 AM
evo500's Avatar
thats the only code? i dont think 02 sensor would deal with vtec kicking in or not.
Old Mar 12, 2011 | 02:37 AM
1sikhatch's Avatar
just hook up the power wire for the light to vtec solenoid wire, so when the vtec pops the light comes on. then u will know if its getting the signal
Old Mar 12, 2011 | 05:31 PM
Eturnatedesign's Avatar
variable speed sensor
crxfreak1117
Feb 26, 2010 06:47 AM
Rob1242
Aug 14, 2009 04:47 PM
bigislandc2
Sep 2, 2006 10:37 PM
theEGkid
Apr 20, 2005 07:56 AM
lemongreenhatch
Jun 23, 2004 07:02 PM
