HID Flickering problem
Old Mar 6, 2011 | 09:28 PM
jdb83923's Avatar
Default HID Flickering problem
Went to install HID conversion kit in my 2000 honda civic and after installing them i turned the lights on and the HID bulbs where just flickering. If some one knows how to fix this can you please help me out.. thanks
Old Mar 6, 2011 | 09:42 PM
94CIV's Avatar
Default Re: HID Flickering problem
Could be bad ballasts.
Old Mar 6, 2011 | 09:46 PM
jdb83923's Avatar
there brand new tho and tried both of them
Old Mar 7, 2011 | 01:53 AM
Libertariat's Avatar
Ek Forever y0!
It's bad ballasts. I assume you've got some cheap Korean HID kit. Are you surprised?
Solution: Get a quality kit. OEM components + Projectors retrofitted into your headlamps. Do it once with quality parts and forget about it.
Old Mar 7, 2011 | 01:57 AM
First.EG's Avatar
some cars need a relay to stop them from flickering. also could be a bad ballast
Old Mar 7, 2011 | 03:53 AM
grumblemarc's Avatar
The Grumpiest
If the stock bulbs work then you got a crappy kit. Not really a Civic issue.
Old Mar 7, 2011 | 06:15 AM
Black Diamond's Avatar
Really lets go to one extreme to the other a 50$ cheap *** hit kit to a $500 Retro fit!
I agree thats the solution but come on!
OP try getting a relay harness and wiring that up and make sure that your left and right headlight fuses arnt getting ready to blow!
Old Mar 7, 2011 | 06:19 AM
Ek Forever y0!
You can do retrofits for as little as $200 if you have patience. FORUM retrofitters also will retrofit your headlights for ~$300 with their basic high/low kit.
$500?
It could be his fuses, but I doubt they'd just hang on with a tiny thread left. Pretty safe bet it's his ballasts. Or they could be really bad bulbs.
Old Mar 7, 2011 | 09:14 AM
Ayyxbro's Avatar
Had the same problem, i had to purchase a ballast that went directly to the battery
Old Mar 7, 2011 | 07:43 PM
jdb83923's Avatar
actually wasnt a cheap hid kid but nice try got em off passwordjdm and i think ill try the relay
Old Mar 8, 2011 | 02:38 AM
Ek Forever y0!
Just because you paid a lot for it doesn't mean it isn't a cheap HID kit.
It's also PWJDM, if you paid $100 for something on their site you can be sure they paid maybe $20 for it.
PWJDM is extortionate.
Old Mar 8, 2011 | 06:15 AM
The Grumpiest
True. Expensive does not mean good. I'm running a $50 HID (until I can ever afford to retrofit) and have been for the better part of a year. No issues.
Old Mar 10, 2011 | 10:23 PM
jdb83923's Avatar
Password uses JD lighting for hids and pretty sure its a good brand but ok
Old Mar 19, 2011 | 03:31 PM
Katastrophic's Avatar
i'm running these and haven't had a problem
http://www.xenonsupply.com/Packaged-...ypage.tpl.html
they claim its for hondas only, probably a gimmeck but hey they've worked for me since day 1
Old May 5, 2011 | 06:19 PM
frustratedriver's Avatar
battery
Old Oct 1, 2019 | 09:51 PM
sansajohn's Avatar
I am using this ballast https://xenons4u.co.uk/mitsubishi-d2...-unit-ecu.html from last one year and haven’t had any issues.
Old Oct 2, 2019 | 04:30 AM
chrysler kid's Avatar
Switch to led. Much less drain on the battery. Get the 3 sided led towers they work great
Old Oct 2, 2019 | 05:36 AM
tony_2018's Avatar
Fish Twig
lazykiwi
Lighting
Oct 11, 2016 12:24 PM
rich3sgte
Lighting
Jan 4, 2011 06:02 AM
93civicsedan
Mar 21, 2007 08:12 PM
shutupitsANDREW
Oct 11, 2004 01:16 PM
