Civic makes a rattle can noise..
I recently went back stock on my 97 Civic hatch and I put in a bone stock d16y8. I also replaced the exhaust system with a bone stock one from a 97 Civic Hatch CX. But now it makes a "rattle can" noise at around 3krpms every time and its sound so nasty.
I am currently using the d16y8 headers which has no cat converter and the stock civic exhaust system from a 97 Civic hatch Cx has no cat on the piping. Could the "no cat" be the reason why its making a rattling noise? Or could it just be a loose exhaust?
Yes I do plan on putting a cat in the future but I have no funds at the moment.
btw I just notice that this is from one of your thread post I jacked the picture from lol
http://www.clubcivic.com/board/showthread.php?t=181893
Thanks I will check all the heat shields. I never knew that a loose or cracked heatshield is the reason why some civics make a "Tin Can" sound... I use to think it was because of no cat or no resonator or bad donut gasket. Is that the case?
Its almost always the heat sheilds if you dont have a cat on it. Or the exhaust could be barley touching something on the undercarrage. Engine vibration, vehicle vibration from the road or just the harmonics of the exhaust can make them vibrate if something is loose.
if u are running no cat.... and running a stock exhaust system... you will have rattle can noise.... so the answer to ur problem is a missing cat....
i remember back in the day when a few people took out the headers from the y7 .. and ran the stock straight pipe with aftermarket headers and stock muffler... it makes a rattle can noise
no cat rattle is around 2800-3k
I love it!
im not sure if the 92-95 have a cat but it should have it.
it is definately the case for EK's....considering alot of my friends made that rattle can noise on purpose by taking off the cat.....
the rattle could also come from those two heats shields, but ive never come across a case like that.
I also checked my piping yesterday for any loose heat shields and they were all secure and stiff as a board. It has to be the No Cat thats making the noise. its very annoying and nasty sounding. Im embarrased to drive so I try to shift earlier like around 2500rpms to avoid the rattle lol
yea obd1 doesnt have a o2 on the cat... only on the header i believe.......haha i hate the noise too.. it makes the car sound all beat up....
u might wana try the whole b pipe off a d16y8 with the cat..... EXCEPT the axle back....i think it will fit not sure
is it a rattling noise coming from the front? like something is tapping against something.... mine does the same thing, pretty sure its because the stock exhaust manifold is cracked completely through on runner 4... you may want to take the heatshield off the stock header and make sure its not cracked..
I sorta had this same problem.. But my exhaust was an after market. I had the tin can noise around 3k rpm. When i went to find the source, turns out it was a resonator. (i think thats what its called) the inside had one of the metal rings that holds the comb outside of it loose.... So of course gutted it all out since i wanted to get rid of the noise. Sometime i will get another when funds are ok.
