B18b in 95 hatch won't start
Old Mar 6, 2011 | 07:07 PM
j4s0n1337's Avatar
Default B18b in 95 hatch won't start
So I was going to work today and my car started to overheat at idle, I pulled over and refilled the radiator and that seemed to do the trick. On my way home however it started to make this weird knocking sound, like a fan was hitting against something, I was about to pull over and look at it when it died on me, and now it wont start. I think I might have burnt out my valve seals, but idk how to check for that, hopefully I didn't spin a rod or anything major. HELP AND IDEAS WILL BE GREATLY APPRECIATED!
Old Mar 6, 2011 | 07:10 PM
Former User's Avatar
Default Re: B18b in 95 hatch won't start
If you can crank the engine, then compression test the cylinders.
Old Mar 6, 2011 | 07:24 PM
95vanditEG's Avatar
when you try to start the car does the engine sound likes its "freewheeling"? or like the timing belt may have snaped...
i have seen a few cars water pump bearings go/leak coolant and then jump time and or break all together... oil/coolant not good for t-belts
Old Mar 6, 2011 | 07:32 PM
j4s0n1337's Avatar
It doesn't crank, and the fuel pump wont prime, I forgot to add that part. The timing belt is still in one piece, I have a feeling it might be my valve seals or something valve related since it was overheating before it died. Can I just pull off the cylinder head to check the valves or the whole head?
Old Mar 6, 2011 | 07:42 PM
The engine may be seized.
Old Mar 7, 2011 | 08:10 AM
j4s0n1337's Avatar
Can you un-seize it or is it impossible? I'm about to take the head off and look around so I'll make another update later today
Old Mar 7, 2011 | 08:31 AM
Check whether you can turn the engine from the crank pulley bolt. If not, the engine is likely seized. In this case, you may want to shop for a replacement engine.
Old Mar 7, 2011 | 09:59 AM
j4s0n1337's Avatar
FOUND IT!
Half-*** McGee (nickname for dude I got my engine from) put on half the bolts to the water pump; rubber ring snapped = my over heating issues. I guessed it caused the timing belt to jump timing, I'm in the process of replacing it and right when I tried to set the crank pulley to TDC I realized it wont turn at all = SEIZED!
ANYBODY WANNA BUY A JDM B18B FOR PARTS?!?!?!?
Old Mar 7, 2011 | 10:00 AM
j4s0n1337's Avatar
Would it be worth re-building? That's a better question.
Old Mar 7, 2011 | 10:19 AM
I'd say shop for a replacement engine.
Old Mar 7, 2011 | 10:21 AM
j4s0n1337's Avatar
Already on it^
KnotInMud12
Mar 21, 2012 06:09 AM
heeltoehonda
Dec 5, 2009 11:39 AM
deathplaza
19
Sep 20, 2006 02:10 PM
Will_H
Apr 18, 2004 03:49 AM
