my a/c blows hot
Old Mar 6, 2011 | 05:45 PM
CivicSi95's Avatar
Default my a/c blows hot
i had it recharged and it blew really cold for a week or so and then progressively went back to blowing hot air. any ideas on where i should start?
Old Mar 6, 2011 | 06:56 PM
Former User's Avatar
Default Re: my a/c blows hot
Was the new refrigerant lost from a leak?
Old Mar 7, 2011 | 08:25 AM
CivicSi95's Avatar
i would assume so.
Old Mar 7, 2011 | 08:28 AM
Find leak, fix leak, recharge.
Old Mar 7, 2011 | 10:01 AM
Crashtestdummy's Avatar
Did you test it and see if it would hold a vacuum for about 30 mins or so? If not do that before you waste more freon. If it holds it for a good 30 mins or longer than its a compressor leak. The seal inside the compressor go bad just like everything else with age. I had the same problem and when i tested it, it would hold a vacuum fine but would slowly discharge over use. It was a bad seal in the compressor, i couldn't find a kit for it to put new seals i wound up having to get a new compressor for it
Old Mar 10, 2011 | 12:43 PM
B_Ray's Avatar
I just dealt with my AC in my EG. I had multiple leaks, one was from the evaporator, another was from the O ring in the low side line & the final was was in the condensor. I would HIGHLY reccomend using a UV light with dye
hopefully this helps.
Old Mar 10, 2011 | 12:51 PM
r.etheridge's Avatar
if you find no leaks like stated above, its your compressor seal. Sometimes you can put the seal stuff( cant remember the exact name) that you can pick up at the parts store for around $25 to help seal small leaks. Small being the key word.
Old Mar 11, 2011 | 11:41 AM
blu3fan's Avatar
check the heater core thing in the engine bay that stops the flow of coolant into the heater core.
could be stuck open
CWJ
Aug 22, 2017 11:34 PM
marqoid
10
Jun 28, 2013 04:41 PM
drpapijr196
Jun 15, 2011 02:17 PM
fromthesun_93
May 6, 2011 06:57 PM
slammed em1
Sep 19, 2009 02:01 PM
