ABS Light
Can't seem to find anything loose, Haven't done anything to the breaks apart from disconnected some plugs near the ecu when it was being worked on, All plugs are plugged in.
Shall i get an error code for you guys ? Or is there a way to reset it to see if it was the plug i unplugged and if not the light comes back ?
Can you give a quick break down on how to reset ECU properly? i disconnected neg bat terminal for over 30 min and didn't seem to do it. also on my todo list was to unbolt the ABS sensor as it was parked up for a few months, are they on all 4 wheels ?
Any time there is an indicator 'ON' on the dash, retrieve the DTC. It will tell you what circuit is affected.
Do not attempt to erase the DTC's until you know what they are. Otherwise you are just throwing away valuable information.
Cool and thats found under the passenger side i seem to have found searching ? short out the two pins with the key in the ignition one click only for electrics and dash board lights.
is there a list for the codes / flashes
i found this thread which i saw is for OBDII tho as i suspect i'm OBDI ? not sure
https://honda-tech.com/forums/honda-accord-1990-2002-2/check-engine-light-codes-cel-diagnostic-trouble-codes-dtc-malfunction-indicator-light-mil-1490107/
At the bottom of that list are the "plain" codes, however those are for the CEL. The ABS codes are different, you'll be counting the ABS light flashes.
Once you get all the codes-CEL, ABS, Trans D4 (don't know if you have an auto?). Post them or google them. I have the manual for the 95 so if you don't find them I can look it up as well.
