Smokes at high RPMS
Old Mar 6, 2011 | 01:35 PM
DelsolVted's Avatar
Default Smokes at high RPMS
i have a 93 del sol auto. i have noticed sometimes when i get on it that at 6k or higher it smokes a lil. looks like grey or black smoke. i do see alot of hondas that do this and i talked to some ppl and they say its normal for hondas. Just want to make sure so thot i would ask. Thanks guys. James
Old Mar 6, 2011 | 01:37 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Smokes at high RPMS
Not normal to any of the Hondas I have ever owned.
Old Mar 6, 2011 | 04:57 PM
41184ek9's Avatar
its normal in any average to high mileaged vtec motor...since the vtec is activated by oil pressure..it is usually attributed to seals allowing oil to leak into the cylinders...take out the spark plugs and see if they are covered in oil...sometimes piston rings depending on the mileage
Old Mar 6, 2011 | 05:15 PM
vondudka's Avatar
The only time I've seen that is like the guy above me said, the seals, more importantly the valve seals. It could be a number of them but I've seen it on a couple of cars as being the valve seals.
Old Mar 6, 2011 | 05:44 PM
DelsolVted's Avatar
the one spark plug closest to the dizzy had oil on it but the plugs never were changed when my aunt had it so i put new ngks in it. so ill just take it easy i guess on or not rev so high.
Old Mar 6, 2011 | 06:43 PM
41184ek9's Avatar
also check the seal on the dizzy to see if its leaking around it or from it
Old Mar 6, 2011 | 07:33 PM
DelsolVted's Avatar
41184ek9 i just did that oring today and a oil change. the old oring was hard.
Old Mar 10, 2011 | 12:47 PM
B_Ray's Avatar
+1 on valve seals/valve seats
Fixxxated
Jul 1, 2011 08:11 AM
banks358
Dec 27, 2009 08:26 PM
rjmancia
May 24, 2009 05:20 PM
93FastLs
12
Oct 10, 2004 08:44 PM
respectblades
Apr 2, 2003 06:26 PM
