map sensor help!!!!
Old Mar 6, 2011 | 01:21 PM
justnprsh07's Avatar
Default map sensor help!!!!
Alright guys I need some help I recently did a little change up on my car before it ran perfect... I went from stock tank, walbro 255, aeromotive a1000 pump on the firewall, and hondata 4bar map, to fuel cell, just aeromotive a1000, achange aem 5bar map
I changed map sensor just bc it screws in over having a vacuum line. So my question is on a s300 what do you set the map as in the ecu? User it as 5bar and my car wont go past 4500 why would this be and what can I do to fix it
Old Mar 6, 2011 | 02:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: map sensor help!!!!
something else may be going on, but for what its worth, my car DID NOT like being installed in the engine. i put a nipple on it, and ran a vac line.
so you do have the s300 set to read the 5 bar?
Old Mar 6, 2011 | 05:02 PM
I'm thinking retune bc I literally parked it running fine changed those things and now it won't run right just checking to make sure I got it in the comp right
Old Mar 8, 2011 | 07:09 AM
Wow does doesn't anyone run a aem 5bar? I just need to know if on a s300 do you load it in the ecu as 5 bar or custom and if custom what do you set it asi
Old Mar 8, 2011 | 07:44 AM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
5 bar
scaler 1250
offset -625
Old Mar 11, 2011 | 02:10 PM
Thanks but wound up being broke plug on the s300 board
dglassmyer
May 6, 2012 06:13 AM
ekk41
Oct 24, 2007 05:28 PM
BEASTLY
Feb 26, 2004 01:27 PM
R THIS
Jun 12, 2003 04:01 PM
DD_JonnyLee
Mar 3, 2003 03:37 PM
