inline pro mani, what bolts for wg and turbo?
i have one of the t3/t4 stainless steel manifold for inline pro, im running an sc34 turbo doubt it matters. What bolts do i use to mount the turbo does anyone know? and should i just run a bolt and lockwasher and be fine? what bolts to use with the wg? its being jethotted that is why i am asking the question so i can buy these beforehand. And ive asked inline pro with no response. thanks
i messaged em twice, emailing seems easier sumtimes, but i looked on the FAQ i found and it looks like 10mmx1.25 or 10mmx1.0. seeing as its my first build, high recommended to run lock washers im guessing
maybe ill just do that then. i know ill have to use a stud or weld one because dude before me broke one wg tread right after about 3 threads idk how
I have the same manifold and turbo. I used 2 exhaust studs and the nuts on the wastegate. I just went to the hardware store and bought 4 - 10.9 grade flange bolts for the turbo. I did not use any lock washers and haven't had any trouble with them. Yes they are M10x1.25x30mm
Edit: Blox manifolds use M10x1.50x30mm
should have looked there before posting.
inlinePro mani takes m10 x 1.25mm thread bolts or studs, not 1.0mm or 1.50. the length is 30mm, that's what sc34dc4 was refering to. the wg is m8 x 1.25 (happens to be the same as oem exhaust mani studs). and lock washers are always a good idea.
https://honda-tech.com/forums/forced-induction-16/almost-everything-you-wanted-know-about-turbo-install-bolt-sizes-thread-pitch-oil-feed-373905/
so you tried threading in an m8 x 1.25 and it didn't work? i find that hard to believe. what exact bolts did you use? were they too big, too small, or wrong pitch? be more specific with your post
Who is Mr Robot?
you lazy ***...... pick up the phone and call inline pro. That way all of your questions get answered and once and this stupid thread **** stops.
silverb18
Sep 14, 2004 09:26 AM
