98 hx obdII port & check engine light dont work?
Old Mar 6, 2011 | 07:22 AM
johnnyboi4o1's Avatar
Icon6 98 hx obdII port & check engine light dont work?
wassup guys ive have search and search but i could not find anything on this but if there is a similar topic please let me know.. with that said i have a 1998 civic hx with a b16a2 swap i had bought the car like that, the previouse owner claims he did everything the right way he said he used the si engine harnes ect. stock b16 ecu now when i try to get it inspected the inspector said my obdII port dont work but i still manage to pass haha dont ask how i know people that knows people so after a week i decided to do a ignition timing adjust and when i try to short the ecu out with that connector the "check engine light" wont come on its not the bulb i checked. so what gives? is something not connected when the previouse owner did the swap? oh yea does the 98 hx comes with power side mirrors? i try to check why my side mirrors dont work so i pulled out the switch and every single wire is cut and i couldnt find the other end. i guess he just had it there for show haha funny people. so any idea?
Old Mar 6, 2011 | 08:58 AM
Former User's Avatar
Default Re: 98 hx obdII port & check engine light dont work?
Does the CEL turn on and then off after 2 seconds when the key is turned from OFF to ON(II)?
Are the 7.5A hood Back Up fuse and 7.5A hood fuse 43 blown?
Old Mar 6, 2011 | 12:21 PM
ReDHaTcHyGuy's Avatar
the port wont work if he is runing a obd1 ecu using a obd1-obd2 conversion harness
Old Mar 6, 2011 | 01:43 PM
94EG8's Avatar
Seagull Management
You can't run an Si harness in a '96 - '98 Civic. If you do you will have several issues. Get a '96 - '98 EX or HX harness and modify it. Also if you have an OBD1 ECU or a JDM OBD2 ECU they wont communicate with a scan tool.
Old Mar 6, 2011 | 05:51 PM
nope dosent turn on at all
Old Mar 6, 2011 | 05:57 PM
kool i did not know that. i will deff look for an ex or hx harness and its runing on the stock si ecu i believe, i know theres no jumper harness though
joe diego
Sep 9, 2017 04:30 PM
kecil
10
May 9, 2011 11:35 AM
GSG2
Acura TL, RL & ZDX
Aug 6, 2004 10:11 AM
phatcivic99
Jun 20, 2002 01:53 PM
