Camber problem
Old Sep 26, 2002 | 09:20 AM
Eg6_JDM's Avatar
Default Camber problem
i raised my car all the way back up simply because i blew out 2 tires.....
now i can still hear the tire scrapping the fork or something....but it wears out on the inside.....
i know i need camber kit but when you raise your car back up should it still be scrapping the tires?? is this problem more than just the cambers going bad
a bit of history*....broke wheel bearing and blew 2 tires on the front....all of this happen on the front passenger side
Old Sep 26, 2002 | 01:56 PM
94gsr's Avatar
Default Re: Camber problem (Eg6_JDM)
You may have bent, or otherwise damaged a suspension component. Take it somewhere & have them check to see if it needs aligned. It WILL need aligned, but many places that I've seen will only charge a minimal fee, if any, for an alignment check. If there is damage, the tech will spot it & let you know. Otherwise, they'll just try to sell you an alignment.
Old Sep 30, 2002 | 03:22 PM
Eg6_JDM's Avatar
Default Re: Camber problem (94gsr)
thanks....
Old Oct 1, 2002 | 08:52 PM
iam7head's Avatar
did you do a alignment when you lowered your ride?
and btw go check the A-arm clearance from the fender too.
good luck
mikbik
13
Aug 28, 2015 03:03 AM
Dj Skidz7
Nov 18, 2007 05:21 PM
POWerTuner
Suspension & Brakes
Oct 29, 2007 04:45 PM
Foxcow
Jun 30, 2007 12:50 PM
gt3civic
May 14, 2007 07:27 PM
