need help quick..please!! starting problem
Old Mar 5, 2011 | 10:45 AM
SiBlueCB7's Avatar
Default need help quick..please!! starting problem
Ok guys please help me out i have a 99 civic with a b16a, jumped to obd1..ok well its turbo and i was gettin it tuned and was gonna switch out dizzys from one of my other cars..well i drove it to my tuners, took the dizzy out without unhooking plugs..and relaized left the dizzy at,my house, put the dizzy back in my car..got home took the dizzy out and unhooked plugs..put new dizzy in..and nothin, sounds like its gettin no compression at all..but its gettin fuel and fire, put the old dizzy in and everything..any ideas
Old Mar 5, 2011 | 10:50 AM
grumblemarc's Avatar
The Grumpiest
Default Re: need help quick..please!! starting problem
"put the old dizzy back on and everything.." Everything is what? And everything is fine? Your new distributor is crap?
Old Mar 5, 2011 | 10:51 AM
SiBlueCB7's Avatar
Put new dizzy, new wires, plugs..and put old dizz back on and same thing..it ran fine with the old one, until i unhooked the plugs on diz did it do this
Old Mar 5, 2011 | 11:06 AM
The Grumpiest
Sure you hooked it back up correctly. If the old one ran fine why did you swap it out? Are you getting any CELs now?
Old Mar 5, 2011 | 11:10 AM
SiBlueCB7's Avatar
Yea both dizzys run in my other car..but neither will run my turbo car? Its like its not gettin any compression what so ever
Old Mar 5, 2011 | 11:13 AM
SiBlueCB7's Avatar
Nothin happened until i unhooked the plugs..and its gettin both fuel and fire?
Old Mar 5, 2011 | 11:20 AM
EFPhilly's Avatar
So you are getting spark and fuel. That is the only two things your motor needs to start.
Did you check grounds and fuses just in case....this is crazy. Im subscribing
Old Mar 5, 2011 | 11:25 AM
SiBlueCB7's Avatar
Yea fuel and spark..craziest thing I've seen in all my years of hondas..ran fine until i unhooked the plugs from dizzy..now sounds like no comp,
Old Mar 5, 2011 | 11:30 AM
EFPhilly's Avatar
And you are sure you did not mix the plugs up. Check that and then change the plugs. When I was untuned I fouled sets of plugs like I changed my undies. Check the wiring as compared to and stock B series motor:
http://hondaswap.com/attachments/452...4-100_5291.jpg
I have done this once. And the dizzy is not 180 degrees off (because you would still be getting spark)
Put motor to TDC of #1 and check your dizzy to be pointing to #1!
Old Mar 5, 2011 | 11:36 AM
SiBlueCB7's Avatar
Well im running a obd1 dizzy..2 plugs...no way i could mix up, its got a good tune on it now, just was gonna do a fine tune, and changed plugs this morning..and same thing..i tried the 180 out, but both dizzys will only go in one way, its not a huge spark..kinda a faint spark..man I've spent a ton of money in this car..please keep me goin with ideas buddy
Old Mar 5, 2011 | 11:39 AM
The Grumpiest
Hope it isn't the ECU. Got a spare you can test it on?
Old Mar 5, 2011 | 11:40 AM
SiBlueCB7's Avatar
Im running my tuners computer, and i put mine in it to check, and nothing again
Old Mar 5, 2011 | 11:41 AM
SiBlueCB7's Avatar
No cel lights either..comes on then goes off like normal
Old Mar 5, 2011 | 11:45 AM
EFPhilly's Avatar
Ecu^^
Are you on S300 or what?
Or if the dizzy has been tampered with like mine was the little 2 prong plug was on backwards on mine. That is why you would set the motor to TDC and check the position...to make sure it matches.
If a engine has spark and fuel...it will start...or at least attempt to. Does it start to go then die or nothing at all? Because nothing would mean ignition related if you are getting fuel.
If its not broke dont fix it right lol just giving you ****. Im going to Film studies class so I will have hours to ponder this question to try to come up with ideas. Hope you find your problem before I get out of class!
maybe this will help:
http://www.samarins.com/diagnose/index.html
Old Mar 5, 2011 | 11:48 AM
SiBlueCB7's Avatar
Im just running a p28 on chrome, and no it does nothing but crank..with no compression doesn't even try to spark
Old Mar 5, 2011 | 11:51 AM
EFPhilly's Avatar
WTF I though you said it had fuel and spark. Then you say it doesnt even try to spark? I think you meant start.
Compression test it because you only need those two things to run it. Why dont you talk to the tuner ey? He prolly knows Hondas well and knows the car better than us.
What is the timing set at on the computer vs on your engine?
Old Mar 5, 2011 | 11:55 AM
SiBlueCB7's Avatar
Baha meant start..and tuner said he's never seen anythin like this happen
Old Mar 5, 2011 | 04:35 PM
EFPhilly's Avatar
Did you disconnect the battery when putting the dizzy on by chance?
I did not get much thinking done in my class...had to take notes, and now have to write a paper...Im no help
Old Mar 5, 2011 | 06:36 PM
SiBlueCB7's Avatar
No i didn't disconnect the battery why?
Old Mar 6, 2011 | 09:22 AM
EFPhilly's Avatar
Did you try checking the dizzy with a multimeter. Checking resistance in the spark plugs. Something has to be throwing off the ignition timing! You said you run a jumper harness. Those harnesses are known for failing sometimes when ppl put them on the floor and whatnot.
The timing is off on something injectors of ignition....
fuel pressure?
How did you check fuel injectors working?
fuses, relays?
This confirms my thought it must be timing:
https://honda-tech.com/forums/showthread.php?p=42748828
Oh I completely forgot about this...what color is the spark. You could be producing a weak spark and not igniting the fuel.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Old Mar 6, 2011 | 01:30 PM
SiBlueCB7's Avatar
Bright blue spark..i think for some dumb *** odd reason it jumped time..it has no compression
Old Mar 7, 2011 | 03:49 PM
EFPhilly's Avatar
no compression when you test it? If it jumped a tooth it may have done something to a valve?
Old Mar 7, 2011 | 03:56 PM
pityocamptes's Avatar
No compression? I've cooked engines in the past that had busted rings and blown holes in the pistons and they still ran, though not the best. Not sure what you mean by "compression"...
AudioFunk
Sep 18, 2013 09:14 PM
89hatcher
Dec 14, 2011 08:04 PM
RanCRX
Mar 21, 2011 03:12 PM
Cashieboi
10
Nov 17, 2006 07:26 PM
