t body issues
Old Mar 4, 2011 | 12:58 PM
f22vtec1's Avatar
Default t body issues
how does a throttle body go bad? is that possible?
Old Mar 4, 2011 | 01:23 PM
grumblemarc's Avatar
The Grumpiest
Default Re: t body issues
Maybe a little back story would help.
Old Mar 4, 2011 | 01:49 PM
f22vtec1's Avatar
friends car wont idle for **** and he was told his tbody is the problem?
Old Mar 4, 2011 | 02:10 PM
The Grumpiest
Doubtful. Maybe troubleshoot for idle problems instead. IACV, FITV, vacuum leaks, etc.
Old Mar 4, 2011 | 02:13 PM
f22vtec1's Avatar
sumone told him they had same issue and they swapped tbody and it ran fine but i told him most likely there tps or map sensor was the issue not the tbody it self
Old Mar 4, 2011 | 02:19 PM
The Grumpiest
Woulda. Coulda. Shoulda. So if he replaces the TB and it doesn't fix the issue what then? Tell your friend to stop listening to other people and diagnose the problem with solid troubleshooting instead of potentially throwing money away for uneeded parts.
Old Mar 4, 2011 | 02:27 PM
f22vtec1's Avatar
i did i was just curious if a tbody can actually go bad if so how
Old Mar 4, 2011 | 02:34 PM
JDMxTai's Avatar
Start the car and give it a little throttle. If it doesn't idle it's not really the throttle body.even with a clogged IACV and open throttle car should still run.
any CEL?
Old Mar 4, 2011 | 02:35 PM
f22vtec1's Avatar
this are his words i havent seen the car yet
he said it wont idle without giving it gas when it's cold if it warms up its fine
Old Mar 4, 2011 | 02:47 PM
JDMxTai's Avatar
I Really Don't want to say its the FITV but it could be FITV.
Someone correct me on this but "isn't FITV suppose to raise cold idles not lower?
Old Mar 4, 2011 | 02:50 PM
The Grumpiest
Don't even know if the car has an FITV. The specs were never given.
Old Mar 4, 2011 | 03:31 PM
f22vtec1's Avatar
doesnt have a fitv
Old Mar 4, 2011 | 03:33 PM
JDMxTai's Avatar
What motor ?
Old Mar 4, 2011 | 03:57 PM
f22vtec1's Avatar
97 itr
Old Mar 4, 2011 | 04:00 PM
The Grumpiest
How about you actually go LOOK at the car and then come back and tell us what is going on with it? This is like pulling teeth as it is.
Old Mar 4, 2011 | 05:25 PM
f22vtec1's Avatar
ok sorry guys i just mainly wanted to know if a tbody can go bad ?
Old Mar 4, 2011 | 09:07 PM
JDMxTai's Avatar
It could Leak from gasket it could get clogged from carbon build up.
Thats all I could really think of.
phelpsj2
Nov 3, 2011 02:35 PM
bluevic99
Jun 5, 2006 02:55 AM
rcjustin
26
Feb 3, 2006 10:37 AM
ATS*Mark
12
Dec 22, 2005 07:14 PM
FourthGenHatch
Apr 29, 2002 11:08 AM
