burnt main board capacitor
Old Mar 3, 2011 | 07:40 PM
the171's Avatar
Default burnt main board capacitor
This has happened on an unmodified B16A (P30) ecu. Never had trouble with the ecu, used for many years on a stock B16. It was removed recently and sent to xenocron for an s300 transformation. They notified me that the ECU powers up, but that there is major burn damage to the main board capacitor. Could this have anything to do with injector wiring? Before removing the ecu installed an obd 1 H22A, with an injector resistor box. Have not tried starting the car, but have cycled the key to run several times before pulling the computer. Input appreciated.
Old Mar 3, 2011 | 07:57 PM
GhostAccord's Avatar
Default Re: burnt main board capacitor
If you never ran the engine for a prolonged time and you installed the resistor box it shouldn't be the injector circuit.
A lot of those caps are coming up on 20 years old and probably near the end of their duty cycle. It's well documented that they will start to leak onto the board and cause shorting.
Do you know what cap it was C14, C12 etc. etc..... that would help isolate the issue.
I replace the caps on all the ECUs that I chip these days, just for that reason. They are only rated for so many operational hrs.
Old Mar 3, 2011 | 08:30 PM
the171's Avatar
thank you ghost accord for this very informative response. I am not sure which cap it was. I am not very knowledgeable of the inside of an ECU. I will post this information when I get it from xenocron. I do feel better knowing that this probably isnt due to my own stupidity, although its possible
Old Mar 7, 2011 | 07:16 AM
xenocron's Avatar
It was C14 and it looks like it just got old and leaked...started eating the board so it was only a matter of time before it failed completely.
We installed a new C14 for you, and had to jump one of the legs on t he cap to a new post but Ian tested it and its all good
jm2000turbo
Dec 1, 2011 04:24 PM
jspec - integra Ls
Dec 26, 2010 08:33 PM
holsetcivic
Mar 4, 2010 07:27 AM
2.3Hatch
Mar 2, 2003 09:32 AM
2.3Hatch
Mar 2, 2003 06:59 AM
