at a loss...radio and cig lighter electrical problems
Old Mar 3, 2011 | 05:43 PM
hoytheld's Avatar
Default at a loss...radio and cig lighter electrical problems
ok...I have a '92 civic hatchback...eversince i have had this car the OEM head unit has not worked (or so i thought)...so I finally installed a new deck this week. well, sitting in the car with the acc on, the unit is fine....when i drive, it cuts on off...on off...it may play for 5 minutes...then shut off for 20 minutes. It is hap-hazzard when it cuts on and off. Also, when the deck is off the cig lighter doesn't work...and when its on the cig lighter works.....sounds like a fuse/power problem right??? well that's what i thought...but, no matter how long the radio is off, the time/station presets are not lost....
I have read in some forums where it may be a bad ground....bad ELD, etc...
I may just run a power wire directly from the batt to the deck to see if this fixes it?
If it is the ELD...where the hell is it located?
any help is appreciated!!
thanks
Old Mar 3, 2011 | 05:52 PM
grumblemarc's Avatar
The Grumpiest
Default Re: at a loss...radio and cig lighter electrical problems
Sounds like a loose ground/power wire.
Old Mar 3, 2011 | 05:54 PM
hoytheld's Avatar
wouldnt i loose the time and presets if it was a loose pwr/ground?
Old Mar 3, 2011 | 05:56 PM
The Grumpiest
I don't know. You didn't say that you were or not. Are you running a harness or is everything hacked up in there. IS the deck and lighter wired together somewhere?
Old Mar 3, 2011 | 05:58 PM
Former User's Avatar
The radio has two power wires, one constant voltage (memory) and one from the ignition switch. The latter wire or fuse may be loose.
hoytheld's Avatar
wires are not hacked...using oem plug/wireing harness
I am NOT losing time/presets
Old Mar 3, 2011 | 05:59 PM
hoytheld's Avatar
where is the ign wire/fuse number?
Old Mar 3, 2011 | 06:01 PM
Yel/Red wire - 15A fuse 23
By the way, this is the same wire and fuse for the cig lighter.
Old Mar 3, 2011 | 06:09 PM
jdmNit's Avatar
im having the same problem except my battery dies out, like i cant run my radio and fogs at the same time or the radio and radar bc my everything just goes dead...ima look into though...hope this thread helps some...
Old Mar 3, 2011 | 06:11 PM
The Grumpiest
Test your battery/alternator. I don't think you have the same problem.
Old Mar 3, 2011 | 06:17 PM
hoytheld's Avatar
so, this is the ign/switched wire fuse?
Old Mar 3, 2011 | 06:18 PM
yes
Old Mar 3, 2011 | 06:22 PM
hoytheld's Avatar
yes
ok...i will check all that....thanks for the info!
Old Mar 3, 2011 | 06:25 PM
hoytheld's Avatar
just for knowing...where does the constant pwr come from...a fused source?
Old Mar 3, 2011 | 06:27 PM
7.5A hood Back Up fuse - Wht/Blu wire
Old Mar 4, 2011 | 12:36 PM
hoytheld's Avatar
ok...little update....
drove into work this morning and same thing...on/off...on/off with no lose of time or presets....so it's obviously a "switched" pwr. So, I removed fuse #23 for the radio/cig lighter and sanded the prongs of the fuse and put back in. The whole way home the radio worked fine as well as the cig lighter....maybe corrosion was my enemy...fingers crossed!
IROCKCIVICS
Audio / Security / Video
Dec 16, 2006 05:21 PM
Arsenal
Apr 24, 2005 07:41 AM
DAYUIZ
Apr 18, 2004 06:01 AM
itsJDMyo
Nov 24, 2003 01:02 PM
dannyboi
Jan 29, 2002 03:31 PM
