OBD0 DPFI to OBD0 MPFI Harness?
Old Mar 3, 2011 | 01:05 PM
Exdeath's Avatar
Default OBD0 DPFI to OBD0 MPFI Harness?
Is there a conversion harness to convert from OBD0 DPFI to OBD0 MPFI or is it all manual re-wiring? (I couldn't find anything on boomslang)
If it is all re-wiring could someone post a link to the best write up for converting to OBD0 MPFI manually? I have found a ton of them, but want to use the most accurate one.
I have a 1991 CRX DX DPFI Automatic, going to ZC DOHC MPFI OBD0 with a JDM PM7 Automatic ECU.
Thanks in advance.
Old Mar 3, 2011 | 03:38 PM
BiG ChOr!Zo's Avatar
Default Re: OBD0 DPFI to OBD0 MPFI Harness?
use you stock wiring harness and convert to mpfi...!!!
https://honda-tech.com/forums/showth...highlight=dpfi
boomslang
Dec 6, 2010 09:37 AM
Eighty-Nyne
May 27, 2009 11:55 AM
koleslaw
Mar 24, 2007 09:39 PM
88da3
Nov 13, 2003 01:12 PM
bossman032
Nov 6, 2003 05:03 PM
