Need help with a y7 engine harness
Old Mar 3, 2011 | 12:13 PM
LOKSTER's Avatar
Icon2 Need help with a y7 engine harness
My question is if a 97 y7 engine harness fits on a 99 y7 engine? Do i need the 99 harness or will my 97 harness fit. I did so reserch and found out the part number on my harness is 32110-p2e-a11 and the other engine has a 32110-p2f-a00.
Will my harness fit as is, modify it, or replace it?
Old Mar 3, 2011 | 12:34 PM
kyden's Avatar
Default Re: Need help with a y7 engine harness
the only thing that wont clip in is the distributor. 99 has a rectangle plug instead of a square plug. so match the distributor to the harness or use a jumper.
Old Mar 3, 2011 | 02:25 PM
LOKSTER's Avatar
can i swap the distributor?
Old Mar 3, 2011 | 05:48 PM
LOKSTER's Avatar
TTT
Old Mar 3, 2011 | 05:55 PM
PyroProblem's Avatar
I know the ecu plugs are different...OBD2A vs. OBD2B
I think something is different with the purge control solenoid by the carbon canister is different too.
Old Mar 3, 2011 | 05:57 PM
LOKSTER's Avatar
OKk so i need 2 get the 99 ecu n harness right
Old Mar 3, 2011 | 06:04 PM
If your car is a 97, and your putting in an engine from a 99 keep your stock 97 harness...
Im pretty sure everything will plug up for the most part (IDK about the distributor)...
I thought you were trying to use a 99 harness in a 97 body...
Old Mar 3, 2011 | 10:58 PM
LOKSTER's Avatar
yes my car is a 97. would it be better to get the 99 harness n put it in???
Old Mar 4, 2011 | 04:58 AM
kyden's Avatar
99 harness won't plug in. use your 97 and swap the distributor.
Old Mar 4, 2011 | 08:37 AM
LOKSTER's Avatar
ttt
Old Mar 4, 2011 | 08:47 AM
No, use the original harness that came with the car..
Old Mar 4, 2011 | 08:49 AM
LOKSTER's Avatar
k thanks 4 the help
Old Mar 4, 2011 | 11:59 AM
Anytime.
Dont forget to thank Kyden!
LOKSTER
Southern California
14
Mar 6, 2011 08:32 PM
GReddy_Civic
Mar 9, 2010 07:56 PM
dragon007
May 18, 2009 09:30 PM
everlight44
Mar 23, 2009 06:18 PM
Zero Signal
Dec 9, 2008 12:04 AM
