Transmission & Drivetrain Gearboxes, Differentials, Clutches
2005 Civic automatic down shifts by itself
Old Mar 3, 2011 | 11:31 AM
jkrown's Avatar
Icon6 2005 Civic automatic down shifts by itself
My 2005 Civic automatic downshifts from 1 or 2 gears by itself, even at high speeds, without my slowing down - even on the freeway. I took it to a transmission shop and they could not find anything, and there are no warning lights. Any suggestions?
Old Mar 3, 2011 | 02:26 PM
David @ Synchrotech's Avatar
Default Re: 2005 Civic automatic down shifts by itself
You may be feeling the torque converter going in and out of lock up. This can sometimes feel like a down shift.
Old Mar 3, 2011 | 02:43 PM
slowcivic2k's Avatar
Gear engagement is controlled by many things on the engine, particularily engine load and throttle position. A lot of things are used to determine what gear the transmission should be in for a given load and speed.
For instance, traversing a large grade at a speed of 60mph will net at least one downshift, if not two, to keep the engine from over-laboring the hill and to maintain your speed.
More information will be needed to diagnose this problem, if it is a problem at all. Sometimes it is normal operation, but that all depends on when it happens and if you can repeat it.
To eliminate to torque converter, which does feel like another gear in most compacts, will usually disengage when the throttle is fully released. Once the throttle is pressed again, the engine will wait for the throttle to stabilize, and then engage the torque converter clutch.
What gear you were in, what speed, engine temperature, kind of terrain, during cornering, etc.
Here is a helpful article I wrote about automatics:
https://honda-tech.com/forums/transmission-drivetrain-127/automatic-transmissions-torque-converters-explained-2086594/
p.b.k
Oct 23, 2010 05:05 AM
alb_accord
Apr 6, 2004 01:23 PM
nijia555
10
Aug 21, 2002 10:06 PM
Turbo Powa
16
Jun 2, 2002 09:19 AM
Grandprix
Dec 11, 2001 10:17 AM
