d15b engine and auto transmission - 7500 rev limit
Old 10-22-2010, 06:55 PM
p.b.k's Avatar
Default d15b engine and auto transmission - 7500 rev limit
i have a non vtec d15b engine and transmission.......the problem is : if the car is at dead stop and i mash out my rpm gauge reach to about 7500rpm before it changes from first gear to second......and sometimes when it reaches 7500rpm.....it gaves a limit cut and then the gear changes otherwise the car works perfect.......WAT COULD BE CAUSING THIS!......i change a bad speed sensor bout 2 weeks ago.....Help PLZZZZZZZZ
Old 10-22-2010, 08:04 PM
CrAzE191st's Avatar
Default Re: RPM problem...need advice
what?
try rewording some of that, can't really understand what's going on.
Old 10-22-2010, 08:07 PM
TwoFaced's Avatar
I'm guessing this is an automatic?
Old 10-23-2010, 04:24 AM
p.b.k's Avatar
Default Re: d15b engine and transmission - 7500 rev limit
yeah it is auto
Old 10-23-2010, 04:26 AM
p.b.k's Avatar
what i say @ craze....is that what would cause my rpm tach to read 7500rpm before going into 2 gear when i mash down....normal it should change at 6800rpm for my model civic
Old 10-23-2010, 05:05 AM
Former User's Avatar
Default Re: d15b engine and auto transmission - 7500 rev limit
Does the transmission change gears properly when driven normally (not WOT)?
aray4762
11-13-2018 12:09 PM
jgauge
08-24-2011 10:06 AM
PhongT12
11-08-2005 02:11 PM
alb_accord
04-06-2004 01:23 PM
Quick Reply: d15b engine and auto transmission - 7500 rev limit
