Suspension & Brakes Theory, alignment, spring rates....
No Sign of Wear on New Rotor
Old Mar 3, 2011 | 11:02 AM
RedDwarf's Avatar
Default No Sign of Wear on New Rotor
I recently had new front rotors fitted on a 94 Accord, along with a new driver's side wheel bearing. The pads were in very good shape so were re-used. The brakes seem to work fine, just as effective as before with no pulling to one side.
The odd thing is that on the passenger side, the rotor shows the normal circular wear pattern but on the driver's side, the original cross-hatching is still present as if the pad is barely touching. The new rotors now have about 100 miles on them.
I took the car back for a check and the mechanic thought they just needed more miles to bed in. He test drove it and verified the brakes were being applied to both sides with the car on the lift.
I also verified that the caliper is not stuck. It slides freely and I was able to push the piston back into the caliper.
Has anyone seen this happen before? Any ideas what might be causing it?
Thanks for any help.
RD
Old Mar 8, 2011 | 05:46 PM
slowcivic2k's Avatar
Default Re: No Sign of Wear on New Rotor
The rotors were probably not replaced as a match set, one probably had been crosshatched with a different cutter, and the other was probably not crosshatched or was otherwise different.
Happens all the time, it takes about 5000 miles for most crosshatches to dissappear entirely.
SiRkid
Apr 29, 2009 08:00 PM
ezol
Jul 24, 2007 02:41 PM
thaseint
Suspension & Brakes
May 1, 2007 09:45 PM
DCFIVER
Dec 22, 2005 02:13 PM
IMMORTAL-B18
Jul 19, 2004 12:37 PM
