can i run 5mm spacers on stock studs?
Old Mar 3, 2011 | 10:21 AM
PowerLeg's Avatar
Default can i run 5mm spacers on stock studs?
i hear w/ spacers past a certain mm you would need extended studs. is it safe to run 5mm spacers on my teg?
rpf1 in 16x7 +43 offset is my rim size i believe
fenders not rolled or pulled
Old Mar 3, 2011 | 10:27 AM
blown_ss's Avatar
Default Re: can i run 5mm spacers on stock studs?
why do you need spacers? yes you will be ok with a 5mm spacer.
Old Mar 16, 2011 | 06:56 PM
PowerLeg's Avatar
whats the most i can run on stock studs?
i want my wheels to be more "flush" for lack of words
Old Mar 16, 2011 | 07:02 PM
James472's Avatar
What offset are you trying to achieve? And 5mm will be fine on stock studs.
Old Mar 16, 2011 | 08:25 PM
PowerLeg's Avatar
^kind of hard to say which offset im trying to achieve
right now my fronts are around -2.xx and rear is 1.9 i believe
i do adjust my ride height every so often or when i feel like it so... not sure here
i just want to look more flush, will 5 do it or will i need more
a little bit sunk would be good for function too so i dont rub everywhere w/o looking super sunk =p
Old Mar 17, 2011 | 05:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
5mm won't be enough to notice.
And you do realize your alignment is also total crap if you change your ride height all the time, right? Toe and camber both change every time you change your ride height, which means if you change it often and don't get it aligned every time, you're destroying your tires.
Old Mar 17, 2011 | 07:59 AM
cletus11's Avatar
What is the thickest spacer that can be used with stock studs?
Old Mar 17, 2011 | 10:49 AM
James472's Avatar
I have +38 wheels, not much of a noticeable difference.
Old Mar 19, 2011 | 07:06 PM
PowerLeg's Avatar
i dont chage the height too much from where it is, not to the point where its alignment is out of my spec range. i've had it brought in to check a few times .
and will +10 make a noticeable difference?
i want it to come out but i still want a slight sink so i wont rub the fenders i'm not rolled in the back or front.
will be on stock studs still
Old Mar 19, 2011 | 11:46 PM
surrealx's Avatar
You should not run any spacer over 5mm on stock studs. Anything more than 5mm you should get extended studs or it will be unsafe.
Old Mar 21, 2011 | 12:56 AM
PowerLeg's Avatar
forgot to mention im on rpf1 and have open holed lugs
edit: no 8? damn was looking to get 35 with that
how much will the wheels go with 5mm putting it to 38?
does the stress caused on wheel bearings that severe or is it something like (will last "almost" as long as if there were no spacers")
Old Mar 21, 2011 | 06:35 AM
Community Builder
It's not the wheel bearings, it's the amount of threads engaged by the lug nuts. Too few threads engaged can cause much higher sheer stresses along the studs.
Old Mar 21, 2011 | 11:39 AM
PowerLeg's Avatar
whats the safe limit?
is it 6+ full turns from when you first put the lugnut on the stud?
Markusss2011
Dec 6, 2011 01:09 PM
2000EJ8
Nov 12, 2010 08:09 PM
messeduprex
Acura TSX
Jun 26, 2010 09:12 AM
Lucky-R
Nov 3, 2006 09:13 PM
b18bfreak
Feb 15, 2003 09:01 AM
