need help with B20 Vtec
Old Mar 3, 2011 | 06:54 AM
hondalove414's Avatar
Default need help with B20 Vtec
I just bought a eg coupe with a b20b with a Vtec head i paid 1900 witch i think is a steal. The car leaks oil right under the distrbuter. and the car idles funny. When i start the car it idles at like 2000 rpm then when it warms up it sits at like 1000 rpm but sometimes when i am at a right light or not moving the idle goes from 1000-1500 it just goes up and down. The CEL is on and idk if this matters but it has a buddy club vtec controller so if anyone can shed some light on these problems i would like to hear what you think is wrong. Thank you....
Old Mar 3, 2011 | 07:53 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: need help with B20 Vtec
High idle at startup is normal. The idle fluctuation may be several things.....IACV, low coolant level, etc.
Yank that crappy VTEC controller out. It is USELESS. Check what CEL code(s) it is.
Old Mar 3, 2011 | 08:31 AM
phaphon's Avatar
and check for a vacuum leak that can cause your idling problem
Old Mar 3, 2011 | 09:38 AM
thecruzs2007@yahoo.com's Avatar
bleed your coolant system, clean your iacv, check for any vacumm hoses that might be disconnected or cracked.. also might be the intake manifold gasket or TB gasket
k_powered_hatch
May 7, 2017 04:47 AM
hollywood97civic
Nov 5, 2012 12:46 PM
GORILLARILLA21
Nov 17, 2010 02:00 PM
uhhhh4doors
Mar 2, 2010 09:58 AM
ECICivic
Jul 14, 2005 12:32 PM
