Gsr swap on DA
What year is your DA?
What year GSR?
The LS engine harness can be used if the GSR is OBD1,if its OBD2,you need to convert the the plugs if I'm not mistaking.
If you're doing a OBD0 to OBD1 swap,you need the 0 to 1 ECU jumper,then just run the Vtec wire to the jumper.
What year GSR?
silk509
May 1, 2010 01:19 PM
