D16Y7 Idle problem
Old Mar 2, 2011 | 05:22 PM
99ek4Dr's Avatar
Default D16Y7 Idle problem
i have the same problem my cel is on and codes are map sensor high input and tps low input. my friend cut my map and tps wires right near the connector i nicely put the connections back and tested the voltage..when i start the car the idle surges about the same in the video posted but faster and it sounds like a leak near the throttle body i have a d16y7...any help? mine does this when idles and dies right when i try to drive it
Old Mar 2, 2011 | 05:35 PM
99ek4Dr's Avatar
Default Re: IDLE problem with 1996 civic
mine do
Old Mar 2, 2011 | 05:37 PM
Former User's Avatar
Are the TPS and MAP sensor connectors swapped?
Old Mar 2, 2011 | 05:43 PM
99ek4Dr's Avatar
i switches the sensors and car sounded like there was some sort of missfire or something it had a deep idle every few seconds i dont know how to describe
Old Mar 2, 2011 | 05:45 PM
99ek4Dr's Avatar
i also checked for a leak around the manifold and there was nothing..it sounds like a whistle or humming noise coming from throttle body. thats why im thinkining maybe t/b gasket leak. I dont think that would cause my car to have the problems its having though
Old Mar 2, 2011 | 05:49 PM
What are the three wire colors in each connector currently plugged into the MAP sensor and TPS?
Old Mar 2, 2011 | 05:55 PM
99ek4Dr's Avatar
i dont remember now but the wires that were cut i put back by matching the colors..i know that is right for a fact i checked about 50 times lol
Old Mar 2, 2011 | 05:56 PM
Can't help you without concrete information.
Old Mar 2, 2011 | 05:58 PM
TB gasket costs $2. Torquing the TB nuts and bolts to spec is free if you have a torque wrench.
Old Mar 2, 2011 | 06:05 PM
99ek4Dr's Avatar
may i also state my iacv connector that was cut off..when i unplug it the idle stop surging but still idles high...when i unplug tps sensor it also stops the surging..its only when there both plugged in that the idle surges i still cant drive with the connectors disconnected it dies right away i also noticed an odd smell in my exhaust like the cars not getting the right air/fuel ratio
Old Mar 2, 2011 | 06:22 PM
99ek4Dr's Avatar
Default Re: D16Y7 Idle problem
any ideas ron?
Smiley Loc
May 11, 2018 01:15 PM
BiG_DeE
May 19, 2008 06:56 PM
heyitzspikey
Jan 29, 2007 09:19 PM
mikeunreal
Oct 26, 2005 05:31 PM
