Bogging and Hestitant B18c1
Old Mar 2, 2011 | 09:48 AM
hmtcrxsir's Avatar
Default Bogging and Hestitant B18c1
Hi everyone,
I got an issue with my B18c1. It started acting up really weird. Whenever I start the car, the car would not idle fine. It feels like a total loss of power and not able to drive it at all. It dies whenever you step on the gas or the engine feels hesitant. On top of all that, the engine sounds like an Subaru STi with an aftermarket exhaust. Its shaking really badly like its going to die. On top of all this, no CEL! So strange. So this is a list of stuff that I did but the problem still persists. I changed the TPS sensor, replaced the gasket for the Intake Mani, changed the rotor and cap, replaced spark plugs, spark plug wires, o2 sensor, and even the headgasket because of overheating issues (I really thought it was the headgasket that cause loss of power). So I rechecked the grounds, rechecking timing, and vac lines. Everything is spot on! But the problem still there. So I thought its the MAP sensor, so I swap that out with a known good one. That still didnt help. I dont know what else to check. Help!?
Old Mar 2, 2011 | 09:55 AM
gus79915's Avatar
Default Re: Bogging and Hestitant B18c1
idk if this applies to b18 but happened to me when i did my d sries i had to switch the tps sensor with map sensor apperently they have the same harness hopefully it works keep us updated!!!
Old Mar 2, 2011 | 10:17 AM
hmtcrxsir's Avatar
if that was the case, the CEL would be on
Old Mar 2, 2011 | 10:18 AM
DCRB's Avatar
a couple of questions for ya;
1 are you running a cat? if so check to see if it's clogged
2 does your cel come on for two seconds then switch off when you first turn your key on?
3 have you performed a compression test and a leakdown test? if not do those next
Old Mar 2, 2011 | 10:26 AM
hmtcrxsir's Avatar
1.) yes stock cat
2.)CEL turns on when key is in ignition and turn to the On position and switch off. Then starts the car. Let it idle for few minutes. No CEL at all. CEL was on before for a bad O2 sensor but I replaced that. So im wondering if maybe it was running too rich and cause the CAT to clog?
3.)did a compression test, 180 across the cylinders. Did not do a leakdown test. Youre thinking a bad ringland? I rebuild the head while i replaced the head gasket. So the head shouldnt be an issue.
Old Mar 2, 2011 | 10:43 AM
gus79915's Avatar
no mine was not on at all the way i was explained is that both sensors are good and its still transmitting some kind of signal so it will not trigger cel like i said it worked for my d series idk if its the same for b but its worth a shot
bertooo
Nov 7, 2011 11:28 PM
hmtcrxsir
Mar 14, 2011 03:58 PM
Touge Tuning
Jul 11, 2005 12:08 PM
SkRiBLaH
Nov 14, 2004 07:34 PM
