Si Airbox versus other models.
Old Mar 1, 2011 | 09:59 PM
sk8shorty012's Avatar
Default Si Airbox versus other models.
99-00 Si
17240-P2T-000 CASE SET, AIR CLEANER (#14)
17243-P2T-000 TUBE, AIR IN. (#16)
96-00 EX
17240-P2J-000 CASE SET, AIR CLEANER (#14)
17243-P2J-000 TUBE, AIR IN. (#16)
Anyone know the difference? Everything else is the same, except for the intake tube of course.
Old Mar 2, 2011 | 02:06 PM
Default Re: Si Airbox versus other models.
anyone know? Where's Amy or RonJ at?
Old Mar 2, 2011 | 02:10 PM
grumblemarc's Avatar
The Grumpiest
The part numbers look the same. Don't think they would need to be different between anything but the Y7 models.
Old Mar 2, 2011 | 02:31 PM
Notice the middle portion, the P2T vs. P2J
Old Mar 2, 2011 | 02:36 PM
canadaek's Avatar
i think that just specifys the model like em1 or ej8 maybe Nofx could tell us
Old Mar 2, 2011 | 05:20 PM
If it's one thing I've learned with Honda parts, it's that a different # means SOMEthing different. Unless of course it's the S84 rear brake pads that interchangeable to EVERYthing basically haha.
Old Mar 3, 2011 | 11:09 AM
Nothing? It's probably not even a big difference, I'm just curious.
Old Mar 3, 2011 | 11:39 AM
NOFX's Avatar
H-T White Ops
I think I figured it out at some point, but I can't recall now. I do know I had an EM1 box and arm on my EJ8 and everything worked just fine.
I'll ask Eran later to see if he remembers any difference.
(Oh, and I believe I still have the EM1 airbox around here.)
Old Mar 3, 2011 | 11:51 AM
Yeah Amy if you would check it out for me I'd appreciate it.
Old Mar 3, 2011 | 12:04 PM
NOFX's Avatar
H-T White Ops
Well, Eran got back to me.
Originally Posted by NOFX
Do you remember the difference between the EM1 and EJ8 airbox? I think it was something tiny and stupid...
Originally Posted by Eran
The arm is bigger for em1
What about the box itself? The part numbers (17240-P2T/P2J) are different, which usually means there's a difference. I doubt manufacturer for two parts that are so similar for the same year cars.
Old Mar 3, 2011 | 12:08 PM
That doesn't help? Haha. I know the arm is bigger, but I'm interested in the box and / or resonator tube.
Old Mar 3, 2011 | 12:13 PM
NOFX's Avatar
H-T White Ops
Yeah, I'm waiting for a reply to that part still. He's at work and I'm texting him.
Old Mar 3, 2011 | 12:18 PM
Gotcha. Thanks for your help.
Old Mar 3, 2011 | 12:20 PM
NOFX's Avatar
H-T White Ops
Just got this.
The inlet outlet might be bigger
Which could make sense.
If you need me to I can see if I can find the OE EM1 airbox and measure or take for real pics.
Old Mar 3, 2011 | 12:37 PM
I would really appreciate it. I'd believe the inlet / outlet bigger statement, however the seals and everything else are the same...
Old Mar 3, 2011 | 12:47 PM
NOFX's Avatar
H-T White Ops
I thought there was only a spring holding it on?
So you have the EJ8 airbox already?
Old Mar 3, 2011 | 01:02 PM
#17,13 and 2 are all the same between EX / Si - the only real places for a bigger inlet / outlet. I don't know what I currently have, there's only a TT-TD40 stamp on it not the traditional S04 or P2J etc. stampings.
Old Mar 3, 2011 | 01:27 PM
NOFX's Avatar
H-T White Ops
Well, mine says (on the underside of 14/the box itself) MADE IN CANADA. On the right side (when installed in the car) it says upside down 0970C and T. On the front (again, when installed) it says HONDA >PP-TD40<. Inside it says upsidedown 381838.
On the lid it says SIEMENS and CC4. Inside it says 381837.
On the resonator's backside it says HONDA >PP-TD40<.
The hole going off the upper right corner (for the tube) measures about 2 13/16 inches across and 10 1/2 inches around the outside.
The oval seal that goes from he resonator to the box measures about 3 3/8 inches across, 2 3/4 top to bottom on the inside. It's 11 3/8 inches around the outside.
The oval hole on the lid is about 3 1/8 inches across and 2 3/8 tall, 9 3/4 around.
The slightly oval seal on the bottom of the box is about 3 11/6 inches across, 3 3/8 inches wide and 11 7/16 inches around (the widest point of the seal/at the edge).
Those are all approximate and I realized toward the end that my measuring tape has metric on the other side. Oops. lol
Old Mar 3, 2011 | 06:39 PM
Thank you VERY much
Once I compare that information to my EJ8 box, I'll report back to inform others of what possible differences there may be.
Old Mar 4, 2011 | 10:38 AM
As far as I can tell, there is NO difference. All the numbers are the same and dimensions, except for the "0970C and T" which I figure is a production number.
05foresterxt
May 4, 2011 10:51 AM
katana600
Jul 12, 2008 05:36 PM
xd69
14
Jun 10, 2005 12:31 PM
aZnjCC
Jul 26, 2004 12:06 PM
