Is this integra worth it?
I am looking on a 96 4door Integra LS with 101k miles. It was crashed in 2007, and had 97k miles. The guy I am getting it from say that he fixed it up, and seem to be decent enough, and decent condition. It is re-painted and everything else seem decent. It drove fine in the test drive. Felt like it shifts fine too.
It has the following check engine light codes. I am unable to find much information about them.
P1792
P0118
P0700
I am getting it for $2.5k. Should I walk away? I am also looking on a 98 4door Civic LX with 105k miles for $3k. Everything is good with the civic, except, it came from FL and so has sun burnt paint, and decently badly need a paint job. This is a car for my sister, with a budget of $3k, it is pushing it, and she wanted it to look pretty. I want reliability more. Both have clean carfax. Should I go with the teg or the civic?
P1792
P0118
P0700
P1792 HONDA - Problem in Engine Coolant Temperature (ECT) Sensor Circuit
P0118 - Engine Coolant Temperature Circuit High Input
P0700 HONDA - Automatic Transmission Fault
walk away!
walk away!
not worth it. For the price of anj ls you can find a gsr. igorka_91 here purchaced a 97 gsr with 115k for $2550. I got my 95 si with 95 gsr swap....clean for 3500. That was cheap 5.5 years ago.
I missed 2 gsr's on CL in cali. 99 gsr with 200k, second owner, older dude, never modded, had no spark for $999. 1996 gsr, clean title, was smoking a bit and needed some motor work, $1200.
Just look around. Take in consideration the $$ and time you'll put into that car to fix the CEL.
Could those codes come up out of replacing the front end with the radiator components?
The car racked up a total of 4K miles in 4 years? It probably sat out somewhere for a long@$$ time, plus with those trouble codes, I wouldn't touch it.
Unless you live somewhere where car prices are higher than normal (such as WA) that seems very expensive for a salvaged car with a bunch of CELs. 4k miles in 4 years also doesn't seem right...
teg_dc2
Jun 16, 2008 01:07 AM
