Car won't go over 3,500 RPM
Old Mar 1, 2011 | 07:53 PM
BIGDADDYCIVIC93's Avatar
Default Car won't go over 3,500 RPM
i got a 93 civic ex with a y 8 head and a z 6 bottom end with a port and polish stage 2 cam in the head ... it will not let me go passed 3500 rpm it cuts out ....i need to know why
Old Mar 1, 2011 | 10:52 PM
tklee's Avatar
Default Re: Car won't go over 3,500 RPM
it might be your ecu or you need a tune. if its not your ecu or tune, damn i dont know hot to help u
Old Mar 2, 2011 | 12:46 AM
Dudeman289's Avatar
i had the same problem with my y8 when i first got it...its your ecu, you need to run a p28 or p2p
Old Mar 2, 2011 | 01:23 AM
First.EG's Avatar
sounds like its in limp mode any CEL?
Old Mar 2, 2011 | 01:27 AM
HondaPartsHero's Avatar
Technical Hero
First off is your check engine light on? If yes than find out what the check engine light is on for by using the faq above.
Old Mar 2, 2011 | 08:26 AM
LL_SP4RROW's Avatar
Spark Plugs
Old Jun 5, 2011 | 09:07 AM
BLAZE_EK's Avatar
Could be a crank position sensor "if it has one not real sure on d motors" or your oil pressure sensor or the dizzy is bad. For sure in limp mode.
grumblemarc's Avatar
The Grumpiest
Old Jun 5, 2011 | 09:25 AM
Gt limited(jdm approved)'s Avatar
check map sensor
Old Jun 5, 2011 | 09:58 AM
Wrona's Avatar
if you cant read the code go to autozone to check they do free tests
Drzhope89
Apr 6, 2016 04:40 PM
Gavin G
20
Aug 2, 2014 05:25 AM
xXCarfreakXx
Aug 9, 2008 11:54 AM
B-serious
Jul 29, 2006 12:00 PM
therealnapster
Sep 28, 2001 11:04 AM
