94 civic no start issues burning IGN COILS
Old Mar 1, 2011 | 08:36 PM
f22vtec1's Avatar
Default 94 civic no start issues burning IGN COILS
my civic keeps popping ignition coils what can cause this?
new wires new cap new rotor new coil **** even tried a brand new dizzy and it popped it withing hours
i was guessing maybe sumthing in the ecu? but wanted to ask here first ?
thanks
Old Mar 1, 2011 | 08:53 PM
Former User's Avatar
Default Re: 94 civic no start issues burning IGN COILS
New plugs?
Old Mar 1, 2011 | 09:04 PM
f22vtec1's Avatar
new plugs wires... distributor **** ton of coils only thing i havent changed is the ecu ! was curious if that could make the ign coil pop?
any other ideas guys
Old Mar 1, 2011 | 09:11 PM
92bseries's Avatar
jus curious but how many grounds do you have?
Old Mar 1, 2011 | 09:14 PM
f22vtec1's Avatar
valve cover block and tranny
Old Mar 1, 2011 | 09:16 PM
92bseries's Avatar
maybe a bad ignition, somethin bad in there thats electrical it sounds like
Old Mar 1, 2011 | 09:18 PM
f22vtec1's Avatar
i was hoping for a ecu problem.... cause my ignition is new as well
Old Mar 2, 2011 | 12:40 PM
f22vtec1's Avatar
no other help guys?
Old Mar 2, 2011 | 12:43 PM
grumblemarc's Avatar
The Grumpiest
I don't know but it sounds like a grounding issue to me.
Old Mar 2, 2011 | 12:44 PM
rxbahamut's Avatar
Look at the wires going to the coil. You might have a frayed wire hitting a ground and blowing it. Try to follow them as far as you can to see if any has any cuts or any way the wire is showing through the insulation.
Old Mar 2, 2011 | 12:52 PM
f22vtec1's Avatar
ok i'll check
Old Mar 2, 2011 | 01:12 PM
Coils generally blow because the HIGH voltage that builds up inside the coil has nowhere to go (ground) when the igniter unit triggers the coil to release its voltage. For example, a common way to blow the coil is to unplug a spark plug wire while the engine is running or cranking. This suggests that the spark from the coil is somehow being prevented from being released from the distributor. Bad plug wires might cause this, so resistance test them. Also make sure the plug wires are fully seated on the cap and spark plugs. Finally, is the inner cover of the distributor installed? If not, this can allow coil spark to jump around inside the distributor.
Old Mar 2, 2011 | 01:32 PM
94EG8's Avatar
Seagull Management
Do you have spark before the coil blows? and if not is the spring in the end of the coil?
Old Mar 2, 2011 | 01:58 PM
f22vtec1's Avatar
i'll be driving then i hear a wierd noise and car dies then i get code 15 replace ign coil and runs again
and no that cover is not in the dizzy
Old Mar 2, 2011 | 02:04 PM
You NEED the inner cover. Get one. And code 15 often indicates a bad igniter unit. Have an auto parts store test it. Do you have an aftermarket distributor or OEM one?
Old Mar 2, 2011 | 02:11 PM
f22vtec1's Avatar
oem b16 and i had just bought a gsr one new from autozone and it did the exact same thing within 1 day
Old Mar 2, 2011 | 02:15 PM
Check the Yel/Grn wire that runs between the igniter unit and ECU for a short. This test requires an inexpensive digital multimeter.
Old Mar 2, 2011 | 02:16 PM
f22vtec1's Avatar
checking for? and is the igniter unit in the distributor?
Old Mar 2, 2011 | 02:19 PM
checking for?
Short = continuity to body ground.
Yes. Have a look at the diagram I posted.
And make sure the distributor installed on your engine always has an inner cover. The lack of one likely caused your current problem.
Old Mar 2, 2011 | 02:20 PM
f22vtec1's Avatar
ok i will check that out very soon
Old Mar 2, 2011 | 02:27 PM
f22vtec1's Avatar
where can i get that cover
Old Mar 2, 2011 | 02:28 PM
Doesn't the new AutoZone distributor have an inner cover?
Old Mar 2, 2011 | 02:34 PM
f22vtec1's Avatar
nope !
Old Mar 2, 2011 | 02:42 PM
nope !
Why would a new distributor lack an inner cover? Or did you just buy the distributor housing? If so, try a local junkyard.
Old Mar 2, 2011 | 02:45 PM
f22vtec1's Avatar
no idea but it didnt have one.... i'll check junk yards
