O2 SENSOR ISSUES PLEASE ADVICE
Old Mar 1, 2011 | 12:51 PM
JDM D15B Vtech's Avatar
Icon2 O2 SENSOR ISSUES PLEASE ADVICE
I have an issue with my o2 sensor on my OBD 1 95 JDM D15B Vtech Del Sol. I recently had the check engine light come on and the code came back as 1 the 02 sensor so i replaced it and the check engine light does not clear i have no clue on what to do i disconnected the battery no luck, i removed the back up fuse and ECU no luck the light still on and i changed the o2 sensor twice just in case it was faulty and still no luck i recently installed a after-market exhaust and i installed the o2 sensor on the header and still no ****ing luck !!!!!
Does any 1 have a clue on what the **** is up with this ****....Please advice !!
Old Mar 1, 2011 | 12:55 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: O2 SENSOR ISSUES PLEASE ADVICE
Did you check for another code?
Old Mar 1, 2011 | 01:06 PM
[QUOTE=mcvtec;44768690]Did you check for another code?
Yes i did and i still get code 1 (O2 Sensor )
Old Mar 2, 2011 | 06:38 AM
slogfilet's Avatar
What ECU are you using?
Old Mar 2, 2011 | 06:43 AM
grumblemarc's Avatar
The Grumpiest
Did you get the CEL before you installed the new exhaust?
Old Mar 2, 2011 | 10:10 AM
I'am using a P28
92-95 Honda Civic Ex/SI / Del Sol SI
Old Mar 2, 2011 | 10:14 AM
The Cel was in the car before the install...i tried everything so far like removing the ECU/CEL 15a Fuse the bacck up one and the hazard fuse i disconnected the battery for 1 day and still...i'am very frustrated
Old Mar 6, 2011 | 11:23 AM
knuxx's Avatar
I hav the same problem here same Engine and Same ECU i still having the cel 41 and i replace the o2 sensor i got a new Denso 234-4099 o2 sensor and still having problems with cel.. help please!!
Old Mar 6, 2011 | 03:23 PM
Eddie 70's Avatar
I had what I thought was a code for O2 also. Turns out it was not code for 02 but was the code for Air Intake Temperature Sensor. What I thought was code 1, short blink, was code 10, long blink. Swapped out my IAT and no more code. I spent money on replacing the O2 sensor plus my time troubleshooting after for what I thought was a bad O2 circuit.
Old Mar 6, 2011 | 03:43 PM
i-VTEC_do_you's Avatar
Not sure what O2 cade u have but those O2 sensors have a heated element, if the code is heater circuit malfunction then you should check the O2 sensor heater curcuit fuse, i think its a 10A
I would check there next, then fallow the wires back to the O2 sensor, make sure there a no breaks in the wires
Old Mar 7, 2011 | 04:55 AM
Thank You All For You Info And For taking The Time To Gide Me In The Right Direction I Replaced The IAT Sensor And The Check Engine Light Is Finally Off. Thanks Eddie70
mattkins91
Mar 1, 2009 02:07 PM
the_0ne
Jul 16, 2006 08:01 PM
Koyoloeor
Oct 13, 2005 04:57 PM
crxtreme27
Sep 19, 2002 02:01 PM
