high compression pistons problem
1996 B18b1 Non vtec
i blew my head gasket i have high compression pistons and stock ls head i bought it that way uhh im looking for a high compression head gasket what i can find is the vtec high compression head gaskets will the vtec head gasket fit the b18b1 non vtec ?? or can i just go to acura dealer and get an oem one? lmk thanks
How high compression are we talking here.. the vtec gasket will not fit the b18b.
The OEM gasket is probably exactly what you need. if the head is not warped, and the deck is in spec, you should be fine. you might have the head and block checked by a machine shop to ensure they are in spec. warpage will just cause you to blow another gasket. Bad machine work, if any was done previously, will also cause it.
you2envious
May 26, 2002 06:26 PM
