Suspension & Brakes Theory, alignment, spring rates....
Alignment Issue
Old Mar 1, 2011 | 09:55 AM
mattyfo0z's Avatar
Default Alignment Issue
So I just got some new wheels tires about a week ago and I just was able to get an alignment done yesterday.
When I put the new wheels/tires on, the car pulled a little to the right so I new that it definitely did need an alignment. Previously, I had steelies with hubcaps and the car drove straight with no problem.
Now after the alignment, my car pulls to the right significantly worse. Nothing too intense, but no doubt more than it was before the alignment.
I called about 15 minutes ago, and the guy said it's most likely something wrong with my car because it's lowered and it suggested things like motor mounts, or something else.
I took a picture of the scanout, so I can get some suggestions. Is there anything wrong with the way they have my suspension setup? Thanks for any insight
Old Mar 1, 2011 | 10:28 AM
mattyfo0z's Avatar
Default Re: Alignment Issue
Better pics...
http://img853.imageshack.us/img853/3874/16487831.jpg
http://img849.imageshack.us/img849/3689/88129975.jpg
http://img195.imageshack.us/img195/1253/73128673.jpg
http://img195.imageshack.us/img195/2498/73260739.jpg
http://img215.imageshack.us/img215/5372/42583883.jpg
Old Mar 1, 2011 | 02:45 PM
TunerN00b's Avatar
No real issues with cross camber or cross caster, and toe looks like it was set correctly (enough so anyway). I wouldn't want that much rear toe in, but that's a personal preference.
Check tire pressures and bushing conditions. Does it actually pull to the right, or is the steering wheel simply not centered?
Old Mar 1, 2011 | 05:06 PM
mattyfo0z's Avatar
It actually pulls to the right. I went down a newly paved road that's really smooth and whenever I let go of the wheel, it pulled to the right significantly.
Any specific bushings or suspension pieces I should check?
Old Mar 1, 2011 | 07:34 PM
bgdriver's Avatar
All of them, make sure both wheels spin freely. If there is nothing dragging or catching and the car still pulls, toe is incorrect.
Align the car yourself with some string and a tape measure to check their ****.
Old Mar 1, 2011 | 09:07 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Well I do see the front left reading negative toe and the front right reading positive toe. That's probably not good. However 0.02" is less than 1/32" and I doubt you'll be able to check that with string.
mattyfo0z
Mar 3, 2011 10:34 AM
evosix
Suspension & Brakes
May 22, 2009 06:42 AM
integra_type-r
Nov 1, 2006 06:33 PM
fabalus206
Oct 1, 2006 01:58 PM
2001civ
Jan 12, 2003 09:50 AM
