Cleaning 1993 Del Sol Engine....
Old Mar 1, 2011 | 09:36 AM
jena_blondie's Avatar
Default Cleaning 1993 Del Sol Engine....
It looks like my 03 Del Sol engine never took a bath since it was born on 1993..lol. Yes, it is that dirty...
I'm thinking about using an engine degreaser and washing it down at a local car wash.
I was wondering if this safe. I'm scared that it would somehow create electrical problems or make the engine check light to come on.
I really want to clean my engine, but I don't know how to do it safely. If you've done this before, please share with me how you did it. What is the best product to use? Is it okay to jet spray the water directly onto the engine and other parts? What should I avoid? I think you get the idea....
Thanks!
Old Mar 1, 2011 | 11:04 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Cleaning 1993 Del Sol Engine....
http://www.youtube.com/watch?v=ghlChTbh4qE
Same principle.
Old Mar 1, 2011 | 11:14 AM
civicsmoke's Avatar
I'd avoid spraying the distributor and if you have an short ram intake avoid spraying the air filter.
simple green is a good product to use to clean your engine.
Old Mar 1, 2011 | 11:17 AM
The Grumpiest
^^ This just to make sure. But I have literally doused all components except the air filter and never had an issue. Wrap both up with a plastic bag if you need to.
Old Mar 1, 2011 | 11:48 AM
Libertariat's Avatar
Ek Forever y0!
It's hard to beat simple green and some elbow grease. A few towels and some simple green will go a long way and do a much better job than spraying the engine down. Steam cleaning works well also.
Old Mar 1, 2011 | 01:02 PM
PSU's Avatar
PSU
formerly DxHatchback
Put a plastic bag over the distributor and then go to town.
Use Simple Green & water.
Old Mar 2, 2011 | 05:35 AM
Sonia's Driver's Avatar
GAHHH. Do not put simple green on your engine! It will oxidize your aluminum parts and make it look like white scale is all over your engine.
It's very easy to clean your engine bay:
* Aquire quarters.
* Find self service carwash (The kind with the hose.)
* Open Hood.
* Insert quarters.
* Spray the engine with the soapy solution.
* When you have a minute left, switch to rinse.
* Rinse the engine. NOT TOO CLOSE! Stay 18 - 24 inches away from the engine.
* Wait a few minutes for the water to drip down.
* Close hood.
* Drive away.
Old Mar 2, 2011 | 03:13 PM
ferioLSv's Avatar
purple power oxidizes aluminum not simple green, ive used it for years with out a problem
donnieb22000
Mar 31, 2018 11:12 PM
v-tecleta
Apr 16, 2006 08:56 PM
Buitrex
Dec 13, 2005 09:42 PM
Siberian Husky
Nov 3, 2005 03:58 AM
