94 civic si/with jdm b20b swap!HELP!
ok heres the deal and whats happening to the car. ok i just did a jdm b20b swap on my 94 civic si hatch and im using all obd1 parts etc. except im running a depin 0bd2a ls distributor and a automatic p75 ecu.....now here the problem the car car starts up and warms up with a little bit of sputtering when starting up for like 3 to 5 seconds then ok after that throwing no check lights for any sensors...then when is fully warmed up i go to turn the car off for a few minutes then i start the car back up then it wont start back up.....thats the problem i have been having is that it wont start back up after when warmed up.....and there is gas and spark from the dizzy ...so here the other thing when i i pull the the injector plug that is caped off for all power ground for the injectors, i pull that off and plug it right back in then i start the car up with steping on the gas it starts up but sputters then idle is normal again this is a weird problem can anyone help out?....thanks
arspring99
Dec 24, 2005 12:27 PM
EH3Kid85
Jun 5, 2005 09:04 PM
