D16B5???
D16B5
(Identical to the D16Y5. Main differences are Pistons, Rods, Camshaft, Head Gasket, Intake Manifold, and Exhaust Manifold are PDN rather than P2M)
* Found in:
o 1998-2000 Honda Civic GX
+ Displacement : 1,590 cc (97 cu in)
+ Bore and Stroke : 75 × 90 mm (3.0 × 3.5 in)
+ Rod Length : 137 mm
+ Compression : 12.5:1
+ Combustion Chamber Volume : 32.8 cc per cylinder
+ Power : 185hp @ 8500 rpm
+ Torque : 160ft·lbf (? kg/m, ? Nm) @ rpm
+ Valvetrain : SOHC VTEC-E
+ VTEC Switchover : 5700 rpm
+ Fuel Control : OBD-2 MPFI
+ ECU Code: PDN-A02
does this really exist? found it on wiki.
* Found in:
+ ECU Code: PDN-A02
http://www.youtube.com/watch?v=jB_kv7dbRLk
http://www.google.com/search?q=D16B5...ient=firefox-a
Apparently they do.
You should search harder.
Apparently they do.
That's what I was thinking. That's what happens when anyone can "contribute" to a wiki.
D16Y5
* VTEC-E
* Found in :
o 1996-2000 Honda Civic HX
o 1996 Honda Civic EX(sedan Peruvian version)
+ Rod/Stroke : 1.52
+ Compression : 9.4:1
+ Power : 115 hp (85.8 kW, 117 ps) @ 5600 rpm
+ Torque : 104 ft·lbf (14.4 kg/m, 141 Nm) @ 4500 rpm
+ Valvetrain : SOHC VTEC-E (4 valves per cylinder)
+ Head Code : P2J
o 1996-2000 Honda Civic VTI
+ Compression : ?:?
+ Power : 127 hp (94.7 kW, 129 ps) @ 5800 rpm
+ Torque :111 ft·lbf (? kg/m, ? Nm) @ ? rpm
+ Valvetrain : SOHC VTEC-E(4 valves per cylinder)
+ Head Code : P2J
+ ECU Code : P2N
+ Piston Code : P2MY
D16Y5
* VTEC-E
* Found in :
+ Rod/Stroke : 1.52
+ Head Code : P2J
+ Compression : ?:?
+ Head Code : P2J
+ ECU Code : P2N
Seriously guys?
It says Civic GX, not HX.
The numbers the OP posted are surely wrong, but no it's not supposed to be the vtec-e variant (D16Y5) from the HX.
A quick google search verifies the GX is the compressed natural gas variant.
Sold 1998+ and each civic model since has had a variation of the engine converted to run on CNG (1.6L 1.7L 1.8L).
http://en.wikipedia.org/wiki/Honda_Civic_GX
nate24740
Honda Civic (2001 - 2005)
22
May 18, 2009 10:24 AM
