what liquid flows through this?
Old Mar 1, 2011 | 04:14 AM
hoytheld's Avatar
Default what liquid flows through this?
Hey all,
I have a '92 civic DX and have a pin (rust) hole in a steel line that crosses in front of the radiator near the bottom of the car. This line is just behind the front lower bumper facia. It comes from somwhere in the engine compartment (i assume) comes accross the front, makes a 180 then returns back to engine. What flows in this? I assume I can "make" my own repair section and scab in a whole new fabbed piece?...doesnt look too complicated.
Thanks
Old Mar 1, 2011 | 04:22 AM
delsolintegra's Avatar
Default Re: what liquid flows through this?
power steering fluid. you can use some tubing and radiator hose clamps.
Old Mar 1, 2011 | 04:29 AM
MR.johnson's Avatar
yup. its a power steering "cooler" take it out and install a real cooler.
Old Mar 1, 2011 | 04:30 AM
hoytheld's Avatar
umm...it's not a race car
Old Mar 1, 2011 | 04:43 AM
N/A's Avatar
N/A
Purpose Built
Who said anything about race cars?
Old Mar 1, 2011 | 05:04 AM
drod's Avatar
Do you guys think anything bad would happen if you just deleted this whole tube, and just connected the ports together closer to the resevoire?
Old Mar 1, 2011 | 05:11 AM
N/A's Avatar
N/A
Purpose Built
No, but is it gets hotter it gets thinner and its more prone to leaks
Old Mar 1, 2011 | 05:12 AM
hoytheld's Avatar
i just ment i dont need to go through all the hoop-la of putting on a "real cooler"...it's a beater work car.... say...
Old Mar 1, 2011 | 05:14 AM
N/A's Avatar
N/A
Purpose Built
If that's the case just do what this other guy said and loop it closer
Old Mar 1, 2011 | 09:00 AM
vtechjunkie's Avatar
I would just be careful what material I used to "loop" that line. I would suck to make a pin hole a huge hole. I would use some small radiator line and a couple heavy duty clamps and tighten them as tight as I could go without crimping the line.
Old Mar 1, 2011 | 10:33 AM
pityocamptes's Avatar
I would tranny rubber line, as rad/water tubing may soften up and deteriorate from the ps fluid...
Cut the line and flare both ends, install rubber line inline and clamp down.
Old Mar 2, 2011 | 05:04 PM
fallrivercolin's Avatar
Is there pressure in that line? I tried using hose and clamps to patch a PS line on my old escort, and it was a messy **** show i tell ya.
Old Mar 2, 2011 | 05:35 PM
Former User's Avatar
Sounds like an A/C refrigerant line.
Andrew14
Jun 30, 2010 12:08 PM
ericstambaugh07
Apr 21, 2007 03:01 AM
Danza
May 26, 2006 07:24 AM
vabchaccord
Mar 24, 2005 11:42 AM
