intermittent starting problem
Old Feb 28, 2011 | 07:47 PM
zacatkings's Avatar
Default intermittent starting problem
I have a 89 y49 crx. The problem is that sometimes when you go to start it, the relays will click, fuel pump primes, but when you turn the key to start the starter doesn't turn. Most times it starts just fine. Problem is intermittent.
Another note, when I bought the car it did have a push button start inside the car. They took the stock starter signal wire off and wired the push button to it.
Any help would be appreciated.
Old Feb 28, 2011 | 08:41 PM
hexrx's Avatar
Default Re: intermittent starting problem
Check that all the wires on the starter are properly connected.. Just went through this and turns out one of the wires was frayed and not making a connection every time.
dustinbs144
Aug 7, 2011 08:54 PM
pooorman's type-r
Oct 7, 2008 03:07 PM
jorge59la
Aug 15, 2007 07:32 PM
Tad
Feb 7, 2006 03:35 PM
